Sandbagging on HP...MAYBE
Old 05-03-2013, 03:56 PM
  #41
Bill17601
AIR FORCE VETERAN
Support Corvetteforum!
Bill17601's Avatar
I have driven many LS3 engined cars. Plenty of horsepower , loads of torque, and fun to drive. Now if my new C7 has the same amount of power as an LS3 I will always be a happy camper. If it has more that is fine but not necessary for me to be happy with my Corvette.
Old 05-03-2013, 04:23 PM
  #42
C5Z
C5Z's Avatar
Originally Posted by red2012
Hey Dan;The engine you're referring to was RPO ZL1, an aluminum block 427 offered during the '69 model year only. The cost was $4718 (base price on a '68 coupe was just $4781) and only two were built. Factory rating was 430 hp but the actual number was much higher. More like around 550.
Right, only a couple aluminum blocks were built, but there were some 216 iron block L88's produced. In 67 & 68 the iron L88 was a $947 option, and in 69 went up to $1032.
Old 05-03-2013, 04:35 PM
  #43
lt4obsesses
lt4obsesses's Avatar
The story I understand is that the L88 was grossly under rated on the order form for sole purpose of discouraging the general public from ordering it. The engine was built for racing applications, forget which series they said, but the class had to use a 'factory' engine. The story I read was that it was fairly close to 600hp.
http://www.thel88corvette.com/
http://www.supercars.net/cars/349.html
http://corvettes.about.com/od/histor...te-L88-427.htm
Old 05-03-2013, 04:43 PM
  #44
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
GM just chose a lower point on the dyno graph to "see" the horsepower rating. the 11:1 CR 427 was rated 435 HP at 5800 RPM, and the 12.5:1 CR 427(L-88) was 430 HP at 5200 RPM.
If GM had chosen to "see" the peak horsepower on that same L-88 dyno graph, it would have been much higher than 430 HP at 5800 RPM.
Old 05-03-2013, 05:00 PM
  #45
Big Dan 427
Big Dan 427's Avatar
Those were the days of 98 octane! Leaded of course.
Old 05-03-2013, 05:07 PM
  #46
svtkeith
svtkeith's Avatar
07 GT500 was advertised as 480 hp it was certified at 500 hp...ZR1 was supposed to be 620 hp then certified to 638 hp...013 GT500 was 640 but it was certified at 662 hp so I have no doubt the advertised 450 hp C7 will be in the 470 plus hp area.
Old 05-03-2013, 05:11 PM
  #47
JoesC5
JoesC5's Avatar
Today's 93 octane is the same as 1967's 98-99 octane, but not leaded as it was back then. The L-88 required 101-103 octane back then.
Old 05-03-2013, 05:16 PM
  #48
Big Dan 427
I remember guys getting Cam 2 that had hi perf. motors.
Old 05-03-2013, 05:43 PM
  #49
JoesC5
JoesC5's Avatar
I don't remember a product called Cam 2 back in the sixties.
Old 05-03-2013, 06:12 PM
  #50
Daniel White
Daniel White's Avatar
It's only speculation, but I wouldn't be surprised if the SAE rating is the same as the publicly released estimated numbers, 450 HP/TQ. They probably have had the numbers dialed in for some time but elected not to release it.
Old 05-03-2013, 06:14 PM
  #51
Big Dan 427
Didn't say 60's. There were lots of 427's in the 70's too.
Old 05-03-2013, 06:27 PM
  #52
RussM05
RussM05's Avatar
Received 1,012 Likes on 365 Posts
40-50 years ago, the marketing department published HP numbers that sounded good rather than based on fact. Also, there was the Gross vs. Net ratings that came into play in 1972. But that was 4 generations of Corvettes back and this is the C7 forum. So if you want to post stuff about HP ratings back then, go to the C3 forum.
Manufacturers can't play games with the ratings today. It will be published based on estabilished SAE rating method.
Old 05-03-2013, 06:39 PM
  #53
C5Z
C5Z's Avatar
True, the ratings these days are pretty regulated and accurate. But the title of this thread feeds suspicion and intrigue that conspiracy theorists love to thrive on; and the L88 shows a precedent of GM underrating, so if you don't want to hear about it don't read on. I'll publish all the figures I care to that are relevant to this thread in regards to the precedent set by GM in the past.
Old 05-03-2013, 07:11 PM
  #54
Chicago1
Chicago1's Avatar
Originally Posted by Daekwan06
I think 475 will be the final number. It accomplishes everything it needs to do. It guarantees the C7 base will be significantly faster than the C6 base.
And 475 approaches C6Z06 "competitive" territory.. while still leaving plenty of room for a 525+hp C7Z06 and 650+hp C7ZR1.
I agree and it seems like some insiders have been saying 475. Forgot what BG said but it was that or 482 between those numbers. Ill put money on it if anyone wants to in on a pool?
Old 05-03-2013, 07:15 PM
  #55
Frizzle86
Frizzle86's Avatar
GM will most likely sandbag the HP ratings a bit. Then as always during the mid cycle re-fresh they will bump up the HP.
I don't really understand all of this worry about the "numbers". Just sit back and wait... I
The numbers that I really can't wait to see, is what happens when some of the tuners like England Green, Cartek, Vette DR's. Get these LT1 engines and see what real numbers they can put down.
Old 05-03-2013, 07:31 PM
  #56
BlueOx
BlueOx's Avatar
Sandbagging...
Old 05-03-2013, 07:35 PM
  #57
HollywoodC7
HollywoodC7's Avatar
Originally Posted by BlueOx
Yup...............be like that mount....jump in....strap yourself to a 400HP engine V8 and pin it and hold on.....No, not straight line it....take it around a road coarse FUll throttle all the time.....NOW? you want to try that with 480?................Id like to see what some do with a mere 400.....these numbers are so chest pounding.....its hilarious....450 will be awesome....
To Sandbagging on HP...MAYBE
Old 05-03-2013, 07:36 PM
  #58
red2012
red2012's Avatar
So whats your point.
Old 05-03-2013, 08:18 PM
  #59
speedlink
speedlink's Avatar
Seeing how GM has been somewhat coy regarding certain aspects of the C7 do any of you guys think they may be reserving the real hp numbers? I think it's fair to say that if the car came out rated 480 plus an awful lot of folks would be real happy!
Hey we might agree. I've been pretty sure for some time now, that they were holding back. Yes, some of it marketing reasons. Also, to help get rid of existing C6 inventory.
Old 05-03-2013, 08:29 PM
  #60
speedlink
speedlink's Avatar
Partially agree. I think if the Z06 comes in at 525HP, you will hear a lot of complaining. Why only 20 HP increase etc. Same with ZR1. Would need more than a 12 HP increase. Wouldn't you agree?
Quick Reply: Sandbagging on HP...MAYBE
