MPG discussion for those who care
I'm a person who actually does care what my cars get for MPG as I daily drive them and do a ton of rural/highway driving.....
Anywho
With the improvements and focus that GM has made regarding gas mileage......
DI
DOD that works very well
VVT
More aerodynamic, less lift
Went to the trouble to create an Eco mode on a 450hp car
7 speed etc
LRR tires (at least in the base?)
Now take what we already have (real world mostly)
C5s can get way more than 30 highway
C5Zs can get more than 30 highway
LS2s can get over 30
LS3s I think can still do 30 or more right?
I've even heard of some LS7 owners claim 28-30 highway, usually 28/29 on the high side
I'm thinking that on a flat long highway doing...idk 55-70... after its warmed up,got a few k miles on it, in 4cyl/eco mode that you'll be able to hit and perhaps hold 40 at least on the DIC in those conditions. Maybe I'm crazy.
Now I know its crazy to even think of making this comparison....but a Cruze eco real world people are getting even 50 in highway/rural conditions and averaging 40mpg a tank. They say you can get the 42mpg highway rating doing almost 80 or so. Totally different situation as the Cruze has a turbo, weighs less etc..but the C7 will still be more aerodynamic and be able to cruise at a much lower RPM I'm really hoping for a good 30mpg highway rating on the sticker. They'll test it in the default touring mode sadly.
So pure highway.....in a VVT 4cyl mode....with a 7th gear....in Eco mode....What do you think? Am I insane?
What are your thoughts or predictions on MPG of the C7?
Anywho
DI
VVT
7 speed etc
Anywho
DI
VVT
7 speed etc
Now I know its crazy to even think of making this comparison....but a Cruze eco real world people are getting even 50 in highway/rural conditions and averaging 40mpg a tank. They say you can get the 42mpg highway rating doing almost 80 or so. Totally different situation as the Cruze has a turbo, weighs less, LRR tires etc..but the C7 will still be more aerodynamic and be able to cruise at a much lower RPM I'm really hoping for a good 30mpg highway rating on the sticker. They'll test it in the default touring mode sadly.
Anywho
DI
VVT
7 speed etc
Started the thread as mainly just an open discussion about MPG and looking for people to respond to my thoughts, but basically the question I added above is what do you think the C7 will do as far as MPG. I'm mostly concerned with real world highway, but I'd love to have any kind of discussion
I guess I'll edit my post to add that
Will the Z51 have the same 7th gear as the base??
Of all the things you listed, this is the one that I'm pretty sure would actually have a negative effect on mileage (the bolded part, at least). More downforce = more rolling resistance.
That said, I am betting this will be the highest EPA-rated Corvette ever. My guess would be that it'll be rated at least about 20/31/25. In that case, I could see ~35 being doable on the freeway.
If it can really do that, it would help make up for the rather disappointing power figures for me. I also definitely care about mileage, both for my sake and because I'm a bit of a tree-hugger.
27 to 32 hwy.
Totally agree.
The only problem I can see for EPA testing is that if they don't allow the car to test in Eco mode, we may not see the huge improvement at least on the sticker. I'm pretty AFM doesn't activate in the normal Tour mode.
If they allow the Corvette to use the AFM during the test, it should see 4 cylinder type mpg.
IIRC - One of the testers was quoted as saying he was getting up to high 30s. I can't find the link, but I believe he had said 38.
I expect EPA ratings of 20/30 for the base and 19/29 (weight, aero and gearing) for the Z51. I also expect that if babied on the highway we'll be able to see 36-38 with 68 MPH cruising.
My coupe got 21 around town and 30 HWY at 70 MPH. My GS lost 2 MPG across the range.
My math: I drive ~13000 miles a year and pay about $4 a gallon. Given a 20 mpg average, that's $2600 a year or ~$215 a month. I'd love to recover some of that cost. If I can get up to a 24 mpg average, it would be a 20% savings. $40 bucks a month is nothing, but I'll take $500 bucks a year over a kick in the teeth any day. I'll just need to remember to sell it to the wife in the form of nice dinner dates courtesy of my more efficient Corvette...
☠☣☢ Semper Ebrius ☢☣☠
Pure highway MPG, which is almost a best-case scenario and not representative of anything other than open-road long-distance travel, is primarily determined by aerodynamics. Pushing 25 HP in air and rolling resistance is still 25 HP even with fewer cylinders. The gain is in pumping losses in the engine, which is (IIRC) around 15% improved. Assuming the same aero losses as a C6, expect a 15% gain in MPG. From 32 MPG that would be 36.8 MPG.
Assuming the same 15% increase for city, expect a change from, say, 18 MPG to 20.7 MPG when putting around in a city (city cycle only, not mixed driving).
Same here. IMO, if you don't get 35+ with the 7 spd manual on the freeway, you aren't trying. If you are trying and can't get that kind of mileage, GM messed up big time.
I'm literally in the middle of 5 different things and didn't spend more than 30 seconds reading your post so maybe i completely missed your point or whatever
Good question, I'd imagine while even holding a lower rpm/steady speed around town or at least while coasting it will still come on...and I'm thinking in eco mode it will get pretty aggressive
