Do You Have To Use Paddles For Rev Matching?
Do you have to use paddles each time you shift for rev matching or do you turn it on or off with a switch?
Does Rev Matching default to Off every time you start the car or does it stay on permanently till you turn it off ?
You know that's a good question. I'm not exactly sure maybe every time you turn the car on, the active rev is on by default then you can turn it off. You might be able to mess with the settings meaning changing whatever the default setting is.
On the 370Z, which is the only other car with a manual transmission with this feature, I believe it stays in whatever setting you put it in even after your shut the car off and turn it back on.
