Will C7 have 1 to 4 skip shift?
got the skip shift eliminator with the skip shift light delete in my 03 Z the first day I got it never looked back. even when you dont shift with light throttle the light still comes on, so the people that say they never see it are BSing.
Silly arguments by those that just say drive it like a sports car. In daily traffic, cruising in town or in your neighborhood...we are not reckless teens anymore. I drive it mellow in such situations, and the Tq of these large V8's have no issue moving my lightweight Z under 1500rpm. Grow up. CAGS is $25 and 15 mins to install and never get annoyed again. Thats a win.
Platinum Supporting Dealership
2015 C7 of Year Finalist
Install the $20 CAGS eliminator, and forget about having to meet any predetermined parameters. Then you can drive it just like you would drive any manual transmission, meaning you shift at the RPM and speed which makes sense at the time and under the conditions of which you are driving.
When I shift into second, with my CAGS eliminator installed, I do it without wondering if I'm driving fast enough, etc to get around the CAGS. I just shift into second gear when it feels right, not when the Nanny allows me.
It's not a matter of growing up, I simply said I don't understand the need. In the current C6 you can actually get to 50 MPH in 1st gear before getting to the red line. My daily driver (non-Vette) is a manual trans with nowhere near the torque of the Vette and I still find myself leaving in first until I'm over 3500 RPMs before I go to second and I travel through traffic both city and highway everyday. I guess it just comes down to driving style and comfort with your car.
In my previous car, 3500 RPM was also the signal to shift, but the Corvette is different. Also, we shouldn't have to compute these things when there's action going on all around.
It's mentioned in these new videos http://www.youtube.com/user/reliablecorvettes/videos . As they keep referencing the owners manual and pages, I expect 'IT' will be available soon.
Bottom line for me is when I expect to be shifting into second gear, I don't want to be shifting into fourth gear. It's distracting when driving in town in traffic, and can be a little disorienting to have the engine bogging and making little power when you're expecting to move like it's in second gear. Situations arise where it's a problem, I know.
I took a smart fuse, cut the fuseable metal arch between the two terminals and soldered in a small resistor that provided enough resistance for the computer to 'think' that the shift-skip solenoid had been activated when it really hasn't been; that's basically what the CAGS eliminator does anyway.
On the C6 at least the fuse for CAGS was independent of any other functions. I hope it stays that way. I expect GM to keep doing us that favor of keeping the CAGS on a separate fuse for easy bypassing. If not, the alternative is crawling under the car and installing a CAGS bypasser there. The fuse version was so easy, though.
TomZ
TomZ
In traffic, the throttle is barely cracked open. Under these circumstances, especially with a great big V-8, it's perfectly correct to short-shift. The problem with CAGS is that there's no way for the car to know that we're settling out at a pace where 4th gear is just bogging.
The car's imperfect knowledge of what the driver intends is the reason we buy _manual_ transmissions in the first place. We shift to second gear because we wanted second, not fourth, and for good reason.
Received 8,926 Likes
Bill
#33
Received 3,803 Likes
"Ask Tadge" Producer
#34
Doesn't "Track Mode" disable CAGS?
#35
I habitually shift mine from 1st to 3rd in daily traffic driving.
Just an ingrained habit, not something I thought of to get around CAGs.
But when I do 1st to 4th, there is not enough power in 4th, unless I go to high rev in 1st. And then the power is unbalanced and car feel for passengers is jerky.
#36
Will the CAGS eliminator void the warranty??
#37
The Consigliere
Received 5,444 Likes
#39
If you are stuck in slow moving traffic with a slow poke driver in front of you you can avoid CAGS by shifting to second early. Shift to second before 15 mph or after 19 mph and you will never see CAGS. If you are someplace where you can use normal throttle then you don't need to worry about what speed the car is going since you will never see CAGS under that condition.
Bill
Bill
