C7 MSRC on Stingray vs MSRC on Z51
Old 08-08-2013, 12:00 AM
C5GoesTo11
C5GoesTo11's Avatar
Default C7 MSRC on Stingray vs MSRC on Z51
I am sure that this is my lack of doing proper research and googling around properly, but I am a little confused on C7 MSRC on Stingray vs MSRC on Z51. I have a '11 GS with MSRC and a '98 with F-45 Ride Control and I really like both of the ride options. My question is, will the ride be different with C7 MSRC on Stingray vs MSRC on Z51 in terms of comfort on long rides or top performance on the track in a measurable way ie seat of the pants or numbers?
Thanks,
--Dave
Old 08-08-2013, 12:03 AM
ZL-1
ZL-1's Avatar
Thanks,
--Dave
There is no MSRC option on the base Stingray. It was eliminated for 2014, will likely return for 2015
Old 08-08-2013, 12:04 AM
Promind
Promind's Avatar
Thanks,
--Dave
You cannot order MR on a non-Z51 model. MR is only available on the z51 package.
Old 08-08-2013, 03:16 AM
Trackaholic
Trackaholic's Avatar
The above is correct. No MSRC on the non-Z51.
From what I gather, the suspension could be arranged as follows in terms of stiffness:
Non-Z51 would be smoothest ride. Z-51 with MSRC is slightly more stiff even at softest setting (mostly due to larger sway bars), and then Z-51 without MSRC is the most stiff (although the MSRC at its stiffest setting would be better for track use).
-T
Old 08-08-2013, 09:06 PM
TX-OU812
TX-OU812's Avatar
What is MSRC?
Old 08-08-2013, 09:08 PM
Snorman
Scraping the splitter.
Support Corvetteforum!
Snorman's Avatar
Received 1,028 Likes on 486 Posts
St. Jude Donor '13-'14-'15
Originally Posted by TX-OU812
What is MSRC?
Magnetic Selective Ride Control...RPO FE4.
S.
TX-OU812
TX-OU812's Avatar
To C7 MSRC on Stingray vs MSRC on Z51
Quick Reply: C7 MSRC on Stingray vs MSRC on Z51
