Air venting in the suede seats
Along the lines of the suede seat inserts of the 3LT Brownstone interior. With he perforated seat you have ventilation/cooling. What about with the suede. Do you sacrifice the ventilation in the suede seats?
Moderator
Here is the jet black with suede inserts. Clearly perforated.
Moderator
This is not real suede (you would not want it to be). It is a man made micro fiber that goes by the trade name of Alcantara or Ultrasuede. The man made version is much more resistant to stains, is more durable and is easier to clean.
Received 4,116 Likes
2020 C8 of the Year Finalist - Unmodified
This is one feature I am really looking forward to in the Vegas heat. My GF's Lexus has it and it works pretty well.
Am I correct to assume "Ventilated Seats" = Air Conditioned Seats?
2016 C7 of the Year Finalist
Hopefully you are right however if it is like the ventilated seats in the new XTS you will probably be disappointed. The air is drawn thorough the seat not blown out the seat. Even on high setting you do not notice the effect at all if the humidity is low. Obviously this is a fairly constant phenom in Vegas. The only time my XTS seats felt cool is when we had "high" (for Vegas) humidity. Then you could feel the cooling effect of the air drawn back into the seats. On the other hand the AC in the XTS is very effective regardless of the temps and will keep you as cool or cold as you like.
Do all the competition seats draw the air through?
Why would they choose to draw air thru? It seems counter-intuitive. Unless they think that a low pressure area under your butt feels cooler. But I would expect that there would be almost no low pressure area under your butt since must of the air will be drawn thru the perforations that are not covered with any body parts.
