Decoding a C7 VIN
Old 08-30-2013, 09:02 AM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,067 Likes on 6,169 Posts
Default Decoding a C7 VIN
C7 VINs include a code that indicates trim level, transmission and Z51/non-Z51:
2014 VIN Decoding:
This is an example of a VIN # for a 2014 Corvette Coupe (3LT, Z51, MN7):
1 G 1 Y L 2 D 7 X E 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
01. "1"= Built in US
02. "G"= General Motors
03. "1"= Chevrolet
04. Denotes the car line: Corvette is a "Y" body.
05. Provides more info about the car:
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
.. 9=export (Non US, Non Canada)
06. Body style: "2" = Coupe, "3" = Convertible
07. Restraint code: D – AJ7 Active Manual Belts, Airbags – Driver & Passenger and Seat Side
08. Engine: LT1 = "7"
09. Check Digit – 0 to 9 or X
10. Model year: E (2014)
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #100001 for each model yr.
The following 4 users liked this post by Zymurgy:
arkayem (09-02-2016), LB001 (05-03-2016), MickP (05-03-2016), walleyejack (08-29-2016)
Old 08-30-2013, 09:22 AM
CantonVette
CantonVette's Avatar
Awesome, thank you! Very informative!
Old 08-30-2013, 09:33 AM
zipcode
zipcode's Avatar
can someone explain what a "check digit" is? all the other codes in the VIN make sense to me except this one
Old 08-30-2013, 09:41 AM
Rich Mickol
Rich Mickol's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Good info. Thanks
Old 08-30-2013, 09:52 AM
GTFD2
GTFD2's Avatar
The Check Digit is one that is used to verify that the serial number is legitimate. I have no idea how it is determined.
Old 08-30-2013, 10:24 AM
Zymurgy
Moderator
Zymurgy's Avatar
The following is taken from Wikipedia reference-linkVehicle_identification_number#Check_digi t_calculation
Old 05-04-2014, 01:16 AM
Rossi6998
Rossi6998's Avatar
Old 05-04-2014, 06:44 AM
Nyvetteguy007
Nyvetteguy007's Avatar
2014 VIN Decoding:
03. "1"= Chevrolet
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
Great stuff!!
Thanks!
Old 05-04-2014, 08:59 PM
AttyVette
AttyVette's Avatar
2014 VIN Decoding:
03. "1"= Chevrolet
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
Thank you for this information!!
Old 05-24-2014, 10:45 PM
checkur6
checkur6's Avatar
Default VIN Number
2014 VIN Decoding:
03. "1"= Chevrolet
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
Is the sequence number a serial number indicating the number of cars being built?
Old 05-24-2014, 11:41 PM
Zymurgy
Moderator
Zymurgy's Avatar
Yes, with some caveats. The Premier Editions are numbered 00001-00500, but the digit before is either 3 or 5 depending on which edition it is. So, the last 6 digits are unique but the highest last 5 digits is not the total production. This also does not take into account the captured test fleet cars.
Old 05-25-2014, 12:05 AM
level6
level6's Avatar
Thank you for all your informative posts. I love all the vette info. Where do you come across all these gems you produce?
Joe443 (08-13-2016)
Old 05-25-2014, 12:36 AM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
A little more caveat: the 53's are 1-500, the 54's are 1-550.
Old 05-25-2014, 03:01 AM
Zymurgy
Moderator
Zymurgy's Avatar
Thank you for your kind comments. I've been researching Vette info since 1998. Probably spend too much time with Google looking for some obscure stuff, like the VIN decoder info, GM Paint Compatibility Guides, etc. Once I uncover these gems, I document them in a Word document and/or with bookmarks (I am also blessed with a pretty good memory). Some info is the collective knowledge of the forum and I just happen to keep track of the interesting stuff per the above methods.
Old 10-27-2014, 07:46 PM
newbie2vette
newbie2vette's Avatar
Thank you for putting this data together, I did not do a lot of research on the C7. actually did not think I would get one, but when I saw the one I purchased. I had to have it, now I doing a lot reviewing what I do have.
Old 10-28-2014, 06:13 PM
AttyVette
AttyVette's Avatar
Old 10-28-2014, 07:31 PM
Jbal
Jbal's Avatar
Very Helpful! Thanks!
To Decoding a C7 VIN
Old 01-29-2015, 06:53 PM
TPVY14
6th Gear
TPVY14's Avatar
Default Question about vin
I have 50000429 I've read the thread but I'm not sure what's up with mine. Any help would be appreciated.
Old 01-29-2015, 07:34 PM
Zymurgy
Moderator
Zymurgy's Avatar
Are you positive the 12th digit is a 0 (zero)? If so, I believe that means you have one of the captured test fleet cars. I assume this was bought used.
Old 01-29-2015, 08:33 PM
TPVY14
6th Gear
TPVY14's Avatar
Yes it is a zero and yes I bought it used. Now I have more questions. Hmm I'll look up that captured test fleet deal. I did get a disclosure from G.M. that the motor was replaced which it now has 500 miles on. But, that's another story....
Quick Reply: Decoding a C7 VIN
