Fuel Pressure?
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
This is the description and operation information for the new 2014 Silverado 6.2 SIDI engine, but I imagine the LT1 is the same or very simalar in specs. GM has been very good about keeping the LT1 info out of the data base so far.
The high fuel pressure necessary for direct injection is supplied by the high pressure fuel pump. The high pressure fuel pump is mounted on the rear of the engine under the intake manifold and is driven by a three-lobe cam on the camshaft.
This high pressure fuel pump also regulates the fuel pressure using an actuator in the form of an internal solenoid-controlled valve. In order to keep the engine running efficiently under all operating conditions, the engine control module (ECM) requests pressure ranging from 2 to 15 MPa (290 to 2,176 psi), depending on engine speed and load.
Output drivers in the ECM provide the high pressure fuel pump control circuit with a 12 V pulse-width modulated (PWM) signal, which regulates fuel pressure by opening and closing the control valve at specific times during pump strokes. This effectively regulates the portion of each pump stroke that is delivered to the fuel rail. The high pressure fuel pump is normally closed and will not deliver an increase in fuel pressure when the control solenoid is NOT powered. In the event of pump control failure, the high pressure system is protected by a relief valve in the pump that prevents the pressure from exceeding 21.5 MPa (3,118 psi).
Here's an excerpt from an article in Hot Rod that was talked about back in Feb. They say it's variable 435-2175 psi. I think all articles that have been discussed here tag it at 2000 psi (+/-).
http://www.hotrod.com/feature_storie...e/viewall.html
Spark Ignition Direct Injection
Hrdp 1302 03 2014 Chevrolet Lt1 V8 Engine Chamber Piston Design
Engineers went through hundreds of possible chamber/piston combinations before developing
The LT1 features the first application of spark ignition direct injection (SIDI) on a pushrod engine. The SIDI system promises to boost power and fuel economy while keeping emissions low, vital for keeping V8-powered performance cars and trucks available in a world where both the market and the law are demanding more miles per gallon. Direct injection requires incredibly high fuel pressure, so a secondary mechanical fuel pump at the rear of the lifter valley is driven by a 5.7mm-lift, three-pointed lobe on the cam where you’d find the cam sensor on an LS3. The pump has its own roller lifter and will boost pressure from the electric in-tank pump to anywhere from 435–2,175 psi and send the fuel directly into the combustion chamber via injectors mounted deep in the lifter valley under the intake ports. Each injector flows 125.7 lbs/hr at 1,540 psi. The injectors operate on 65 volts and are controlled by a new E92 ECU. Because of its precise fuel metering and in-cylinder fuel atomization, direct injection will allow for a compression ratio of 11.5:1, up from 10.7:1 in the LS3 and even higher than GM’s direct-injected 3.6L V6’s 11.3:1 ratio.
Direct injection’s high pressures mean that the pintle in the injector hammer opens and closes with a lot of force, which can cause a heck of a racket, not unlike a diesel. To minimize noise, the fuel rail has isolators to keep the pulsations from transmitting through the engine, and the injectors are suspended rather than hard-mounted, allowing them to slide up and down in their chamber in the cylinder head.
If you look up any car running DI and aftermarket FI you will notice that no one messes with the DI side as you speculated, it's expensive and messing with it can and will result in detonation. DI is not what you think it is, which I am going to assume that you think it is the primary fuel introducer to the cylinder. DI is used to allow higher compression engines to run more efficiently by introducing cold high pressure atomized fuel to the combustion chamber which allows the higher compression on pump gasoline. The port injectors is where tuners are altering the amount of fuel being introduced into the cylinder. Tailoring fuel maps to achieve an ideal A/F ratio via the port injectors is pretty much the only way currently to FI these DI engines without having to go with a standalone ECU setup.
I am currently running a similar setup in my FR-S with no issues, engine temps are marginally higher (5-10 degrees C) so it's not perfect but that is no big deal to be honest. I am running 750cc injectors and a 290LPH fuel pump as well just in case I want to tune her to 490-500WHP. Ok thats a lie...I am not tuning her that high because i don't want to break anything before I sell her for my C7
Here's a before and after of my engine bay:
Stock:
Current:
Stock:
Current:
Stock:
Current:
Stock:
Current:
I've wondered if you could run a hybrid set-up with two fuel systems, a high pressure DI system and a low pressure throttle or port injection system, so that you could control f/a even with FI. If you read airflow with a mass flow meter on the front end and know what the DI system is going to meter out, then you should be able to meter the "make-up" fuel from the port system pretty readily, and accurately control f/a.
Stock:
Current:
Stock:
Current:
The fuel pressure range for the LT1 is up around 2800 psi or close to 20 MKpa. Yes they are complicated systems for sure but we have already recognized the issues in getting enough fuel mass to make power at levels to feed the hungry consumer.
The pump is a positive displacement pump so its "limited" on total flow as is the injector. Yes its costly stuff but if you want to play your gonna pay.
We are pretty well into our modified pump and will have it on a car for PRI. The injectors are a longer process as the correct way to deal with it is make a new injector. The DI injector is VERY complicated with spray pattern and modifying it will totally screw it up. Unlike "drilled" port fuel injectors (which most have dirty spray patterns) if the injector spray path is not in the path of oncoming air flow into the combustion chamber lots of issues will arrive during the combustion process.
We've been on this for a few months and have been working on the solutions to be able to feed 800 BHP...
Howard
Nice setup.....
Howard
Howard
How much hp can the stock fuel system handle?
My 3V s197 stock fuel pump can handle 450whp 39lb injectors. I imagine an LT1 stock system could support 600bhp. That's all I'd want.
So there are typically three limitations to fuel delivery in a direct injection system. The first is the low pressure side fuel pump, similar to the fuel pump in port injection system. That's easy enough to replace.
The next is the high pressure fuel pump. Currently there is a small aftermarket for basically modified high pressure fuel pumps that can maintain fuel pressure better as injection duration increases. The newest direct injection systems run 15 or 20 mPa (150 or 200 bar) max.
Finally, there is the injector itself. The injectors are sized by the OEM so that they can meet flow requirements within a certain injection timing window. A typical start of injection timing for single pulse injection is between 260 and 340 degrees BTDC. The latest end of injection timing is usually around 120 degrees BTDC. If you go earlier or later, you start hitting the piston, valves, cylinder wall, etc (especially on a side injection system like this). In contrast, port injection can run almost the entire 720 degrees of crankshaft rotation for full load open-valve injection.
You can increase fuel delivery by increasing injection time, as long as the fuel pumps can flow enough maintain the pressure. The longer injection time will result in higher amounts of smoke and oil dilution however, as the fuel impinges on the piston, walls, and valve(s).
Only Toyota/Subaru and VW/Audi use a combination of port + direct injection, and VW doesn't use port injectors at the same time as the direct injectors. All the other systems use direct injection only. Typical aftermarket solution is modified high pressure fuel pump, aftermarket low pressure fuel pump, and longer injection times at max rail pressure.
Nice setup.....
Howard
Howard
FWIW, GM finally released their service information for the C7. They are showing DI fuel pressures from 290 to 2,176 psi and a compression ratio of 11.0:1
Also the compression ratio and pressure noted in the service document are different from some other SAE documents regarding the GEN5 engine.
Higher pressure is part if the equation in expanding the fuel system range from its current design.
HT
