Anyone brave enough to post front license plates holders?
I was installed mine using the "flat" bracket, but before I put it on the corvette one, I wanted to see some pictures. Show us those front plates!
I think I figured it out, two different plates. Use curved plate, drill holes to mount plate, bend plate a bit then snap into bracket for the curved plate that has been attached to the grill. The flat bracket sarge for states that have to be a minimum height.
Is a cop actually going to measure this if it mounted to either bracket?
Received 9,518 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
The last pic is least "fugly".
The flat bracket is very ugly!!! It's an engineering marvel brought forward from the C6. But I am really confused as to the reason for the bracket with the corvette plastic plate on it. If you snap off the corvette plate the mount has a picture of a license plate embossed on the surface with a slash thru it. I take that to mean it is not to be used as a license plate mount. What the hell is it for?
I believe GM put that on there because some states have minimum height requirements. I intend to use the curved plate, drill holes and go. No cop would measure the height,. In addition it is the same as the Top Flight I ran for 6 years with no problems
http://www.corvetteblogger.com/2013/...-plate-holder/
Exterior Design Manager Kirk Bennion explains no drilling required front plate mount....
http://www.corvetteblogger.com/2013/...license-plate/
