Front plate install step by step with pics
Moderator
That being said, the front plate on the C7 doesn't look nearly as bad as the C5 or C6 so I will probably put one on when I get a C7....just for peace of mind...
The "bent Corvette" license bracket comes in 2 pieces. So you dont have to drill thru the corvette panel. 1) Remove the panel 2) Turn it over and drill GUIDE holes thru holes already in the back, you will see them when you turn it over. 3) Install the BIG black license hardware, loosen the black bolt all the way. 4) Intall on car, tighten the black bolts all the way. 5) Install plate with screws in the guide holes your drilled.
Now that the law has had its glitch fixed this year, Texas DPS will be out enforcing the front plate with renewed vigor. Yet they couldn't prevent the governor's mansion from being severely fire damaged several years ago due to an arsonist and the result was many millions of dollars to restore.
One question - I am thinking of installing my license plate over the "Corvette" cover. In looking at your plate, did you ever consider the way I am planning to install it? The reason I'm thinking of doing it is it seems to fill it out better verses the indentation you have on yours, I don't know yet for sure, but why have the Corvette plate in the first place if it wasn't meant to be used some way? Any thoughts anyone?
#33
According to some of their officlals, Mercado ind is in the final stages of their removable license plate bracket for the C7 and it should be available to us in the next 30 days or so. According to them, It will look and function just as the C6 Zr1, Z06 and GS version. It will be made completely from carbon fiber and will sit lower than the GM version. I have one for my ZR 1 am completely happy with it. I put it on when I drive and take it off when at home or at shows. I personally like the way the bracket looks and the way it sits on the car.
#34
Hello,
A picture of their new removable front license plate bracket for the C7 Stingray, from their facebook page. The positioning looks nice IMO.
https://www.facebook.com/home.php?ref=wizard#!/
#37
Not much to add to OP's tutorial, but I think the install looks better with a license plate frame added....Cruzer has a polycarbonate one that is flexible so no problem with the curve as seen below....
#38
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Actually, I had a similar plate on my C6 that was the same size as the plate and was less noticeable then the C7. But then again, I did not need to buy the C7 bracket. I think it looks okay. Thanks for the post.
#40
St. Jude Donor '04-'05-'06-'07-'11-'12-'13
the C6 plate bracket was from TopFlite Reproductions and is very similar in looks to the C7 bracket. The C6 plate was attached with double stick tape and was removable with 2 wing nuts. I had their bracket on all 4 of my C6 cars.
Mike
Mike
