Breaking News: Is this the C7 ZR1′s Supercharged Powerplant?
Old 10-08-2013, 07:16 PM
  #41
MikeyTX
Support Corvetteforum!
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Wow ........... Are Ox and I going to have some fantastic low mileage pre owned to choose from once this baby hits the street.
Old 10-08-2013, 07:17 PM
  #42
CarBoy
CarBoy's Avatar
Please GM...PLEASE!!! NO STUPID WINDOW!!!!!
Old 10-08-2013, 07:27 PM
  #43
Knome
Knome's Avatar
Originally Posted by meadowz06
I say 700hp easy. If not more than 638, then why redo?
I say 1000 rwhp...after all, isn't that enough?
Old 10-08-2013, 07:32 PM
  #44
Knome
Knome's Avatar
But you'll have to deal with ill fitting interiors, poorly fitted rear wing, LED's out in the information system, pink, leaking fluid under the front fender, orange peel paint (well, you are probably use to that one already)...did I forget anything?
Old 10-08-2013, 07:44 PM
  #45
BlueOx
BlueOx's Avatar
Yup!
Old 10-08-2013, 08:02 PM
  #46
Houston Z33
Houston Z33's Avatar
Add me to that list!
Old 10-08-2013, 08:05 PM
  #47
RandomTask
RandomTask's Avatar
Because they want to sell the cars and not make a super expensive car no-one will buy. Seriously - $130k corvette?
The LS9 in the ZR1 only share a block with the normal corvette ls(3); everything else is unique: crank, rods, pistons, valves, heads, etc. This and the fact the engines are hand built, drive up the cost significantly.
Now imagine taking the same short block of the LT1, and throwing a different intake/heads/cam on it? You know, like what they did on the LS1 vs LS6?
600 HP is nothing to sneeze at . . .
Old 10-08-2013, 08:11 PM
  #48
keagan
keagan's Avatar
Awesome, I love this stuff. As things were dying off we got a little spark. Thanks OP! Question is whether a Z06 will be on the line or not. Hoping its in excess of 600hp.
Old 10-08-2013, 08:13 PM
  #49
Robs98Z28
Robs98Z28's Avatar
Is the assembly attached to the back of this the clutch housing that transitions into the torque tube?
Old 10-08-2013, 08:42 PM
  #50
rcallen484
rcallen484's Avatar
Compare with real deal LT1 setup:
Old 10-08-2013, 10:21 PM
  #51
skank
skank's Avatar
Received 1,155 Likes on 516 Posts
Yup, Looks like the new ZR1-LT4 motor to me. Notice the lettering Font on the supercharger top is exactly like the font on the LT1 motor. It is an exact match.
Old 10-09-2013, 12:01 AM
  #52
dmaxx3500
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
it will be called ''L88''
Old 10-09-2013, 12:59 AM
  #53
JCtx
JCtx's Avatar
Obviously a ZR1 engine, since it's a supercharged LT1. The better question is if the Z06 is dead or not. Or at least the GS. There's no way we're going to see all 3 back. And the one that makes more sense to ax is the Z06, since a larger engine just doesn't make sense at this time. We'll find out soon enough .
Old 10-09-2013, 01:11 AM
  #54
kozmic
kozmic's Avatar
I tend to agree. It is well known that the 2009 ZR1 only came to be (in addition to the then already existing Z06), because GM wasn't ready to do the C7 yet and was trying to re-energize popularity of the C6 run for a few more years. (and I am very happy they did )
I too believe there will only be one Z06/ZR1-level high-performance model C7 (unless of course we see a nine or ten-year run for the C7...), and I believe it will be called the Stingray L88 Code and will have this "LT4" PD SC'd motor.
Old 10-09-2013, 02:40 AM
  #55
Stingray23
Stingray23's Avatar
IF we see 2 more models, I think this will be the Z06 model engine. I think the ZR1 will have an LT5. Same engine name as the original ZR1's of the 90's.
Old 10-09-2013, 05:59 AM
  #56
C7Z
C7Z's Avatar
I was hoping N/A motor (lighter, less heat), but will see the final product
Old 10-09-2013, 09:00 AM
  #57
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
The ZR1 was well into development long before the economy crashed. It was not a spur of the moment decision in 2008 to produce another model for the 2009 model year.
To Breaking News: Is this the C7 ZR1′s Supercharged Powerplant?
Old 10-09-2013, 09:07 AM
  #58
lt4obsesses
lt4obsesses's Avatar
If you mean a DOHC engine, maybe, but it seems like it would be very difficult to fit one in the low hood profile existing now. I believe that was one of the reasons they stated when asked about sticking with the pushrod.
Back in Jan/Feb there was some info out that they planned this generation for a five year run, true or not, who knows? However, if that's the case then I would expect only one Hi Po version. Keep in mind that the ZR1 exists only because the C7 project was shelved back in '08. The ZR1 was designed and produced to keep fresh blood in the Corvette line up. This from Juechter on vid from Carlysle back in '11 or '12. It's in the vid section I think. I believe that they will not neccessarily set out to outpower the ZR1 and leave it as the classic it is. This would be good news for those current ZR1 owners down the road.
While I too have a much greater appreciation for N/A engines, Forced Induction is here to stay. It is simply the most efficient way to boost power levels and maintain acceptable fuel economy. Which is a factor like it or not. If gas jumps this coming summer like it did last summer, we will be looking at premium fuel flirting with $5/gal. If they want to keep Corvette affordable and obtainable, a huge factor in it's success, it must also be affordable to own and drive. Forced induction is how they make that happen without adding cubes and increasing fuel demands. The supercharger is the probably the most effective and reliable way to do that. I would look for this engine to produce about 100-120 more HP than the LT1.
If they can then put it into the current chassis, adding perhaps carbon ceramic brakes and fitting for a little more tire, maybe they can sell it for a base price of $75-$80K, or just a slightly more than the Z06.
This is just my opinion based on observation of the auto industry, and I do reserve my American Right to be full of Sh*t.
Old 10-09-2013, 09:23 AM
  #59
travisnd
travisnd's Avatar
This is not true. The ZR1 was in development well before the crash/great recession BS.
As for this motor... I think people are off-base trying to compare to the existing base/Z06/ZR1 structure of the C6. I think we're going to see the standard Stingray and one hi-po variant. GM would be stupid to make a $130k Corvette in this economy. Just look at how well the Vipers are selling.
Old 10-09-2013, 09:38 AM
  #60
BlueOx
BlueOx's Avatar
Dying off? It's all just ramping up! We're just a month into deliveries!
Quick Reply: Breaking News: Is this the C7 ZR1′s Supercharged Powerplant?
