Anyone have a steering problem ?
Old 10-12-2013, 04:56 PM
C7 101 car
C7 101 car's Avatar
Default Anyone have a steering problem ?
When I turn the wheel All the way to the end (like when backing up on a smooth driveway) the steering feels bumpy/jerky & makes noise like when I am on a bumpy road.
The same thing happens turning All the way going forward on a smooth driveway.
Is this normal ?
Does anyone notice this?
Old 10-12-2013, 04:59 PM
rcallen484
rcallen484's Avatar
Same as on C6. Someone said someplace it has to do with front tire width. Don't know if that is accurate, but it is true of every single one, not in any way an individual car thing
Old 10-12-2013, 05:01 PM
Voytek
Voytek's Avatar
I get it on my zo6. tires. normal.
Old 10-12-2013, 05:02 PM
4GS7
4GS7's Avatar
Ackerman angles due to the location of the steering rack. Your car is fine. It has little to do with the width of the front tires.
Old 10-12-2013, 05:05 PM
rcallen484
rcallen484's Avatar
Oh, yeah, Ackerman angles, what could that person have been thinking?
Old 10-12-2013, 05:37 PM
Bill B 1
Bill B 1's Avatar
It mentions it in the owners manual as well.
Old 10-12-2013, 05:38 PM
rcallen484
rcallen484's Avatar
The Ackerman angles?
Old 10-12-2013, 06:41 PM
Bill17601
AIR FORCE VETERAN
Support Corvetteforum!
Bill17601's Avatar
It does not happen as much with warm tires. I turn the wheel less when coming out of my driveway and it does not happen.
Old 10-12-2013, 06:51 PM
R&L's C6
R&L's C6's Avatar
Received 1,250 Likes on 706 Posts
Do the Ackerman angles lesson when tires are warm?
Old 10-12-2013, 06:53 PM
Bill17601
AIR FORCE VETERAN
Bill17601's Avatar
I have no idea. I can only tell you what my car does. I am not into science but I do enjoy reality.
Old 10-12-2013, 07:08 PM
EpicC7
EpicC7's Avatar
Completely normal, other high performance cars do this as well.
Old 10-12-2013, 07:19 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
It seems that some cars have more of a problem than others. My C5 with the OE Goodyear's was quite noticeable but diminished greatly when I installed Michelin tires.
My C6 Z06(with much wider tires than my C5, or a C7) is hardly noticeable, with either the OE Goodyear' or the replacement Bridgestone's. And that was with both the factory alignment or the less aggressive alignment I had done with the Bridgestone's. At full lock on my Z, you can barely feel it.
Old 10-12-2013, 08:52 PM
zipcode
zipcode's Avatar
Is this normal ?
I get this too, but as others have already said, it's normal and it's also mentioned in the owner's manual too
Old 10-12-2013, 08:58 PM
TacDoc
TacDoc's Avatar
Is this normal ?
Tires.
Old 10-13-2013, 12:38 PM
C7 101 car
C7 101 car's Avatar
Thanks for all the responses
I am glad it's not an individual car thing.
I had a 1997 C5 NON Z51 and don't remember this at all.
Old 10-13-2013, 02:27 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Wikipedia reference-linkAckermann_steering_geometry
Old 10-13-2013, 02:56 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It's not a "problem" it is a characteristic of wide tires. When you turn full lock in either direction, the two wheels are scribing two different radii as they travel through a turn. One is turning along the arc and the other is scrubbing along the pavement when it tries to scribe a different arc.
To Anyone have a steering problem ?
Old 10-13-2013, 03:00 PM
kirbsc
kirbsc's Avatar
Talon90 - thanks for the post - absolutely correct. Great tires on tight turns!!
Old 10-13-2013, 03:10 PM
MikeG37
MikeG37's Avatar
With my '99 C5 it's more noticeable when going forward. My father's 60th 427 convertible I almost can't feel it moving forward. But in reverse you can really feel it.
Old 10-13-2013, 03:14 PM
VETJAZZ
VETJAZZ's Avatar
Get it on my C5 with new Michelins. Don't remember it as much with the original Goodyears.
Quick Reply: Anyone have a steering problem ?
