** C7 Reported issues and resolutions thread **
Old 10-14-2013, 10:11 AM
lggque
lggque's Avatar
VIN #685
Piece of plastic hanging down under the front right side near door jam. Dealer is ordering a replacement part.
lggque is offline
Old 10-14-2013, 10:30 AM
george vee
Support Corvetteforum!
george vee's Avatar
Received 1,073 Likes on 532 Posts
2015 C7 of the Year Finalist
Originally Posted by bluedevil 1
2014 vin#53 Premium Edition When in reverse and the camera is on, I can read a good portion of my license number. Both I and the dealer have looked for a adjustment, no joy. Am wondering if we are incorrect?
I could read my plate also. I think the camera should be set a bit higher.
george vee is offline
Old 10-14-2013, 12:56 PM
jgeer
jgeer's Avatar
Default Back up Camera
I've noticed the same thing on my temporary license plate' Vin #70
jgeer is offline
Old 10-14-2013, 02:10 PM
Bisha
Bisha's Avatar
Default Possible HUD Problem
C7, Auto, Coupe - My HUD display seems to be tilted just slightly. The bottom line of green bars seems to be a bit to the right and what should be the vertical lines of the bars are tilted a bit thus making them display a bit of pixelation instead of being totally vertical. Anyone notice this or am I just seeing things?
I have a C6 also and its HUD as no issues like this.
Bisha is offline
Old 10-14-2013, 05:11 PM
VNAMVET
VNAMVET's Avatar
Same here...vin 2839
VNAMVET is offline
Old 10-14-2013, 05:21 PM
Cruiter
Cruiter's Avatar
On order: Torch Red Z51
They all do. It's actually an illusion from the hood angles making it seem that way I believe. But just something to get used to, they're all the same.
Cruiter is offline
Old 10-14-2013, 05:31 PM
speedlink
speedlink's Avatar
My first guess is, that looks level. I think the orientation of the hood makes it look that way. IMHO of course. Let us know the outcome.
speedlink is offline
Old 10-14-2013, 09:31 PM
cbboarder
cbboarder's Avatar
AW Z51 NPP MRC 7sp 1LT
VIN #2699
A few cosmetic issues here.
1. Hood mis-aligned. Left side is higher than right. Decided to drive around to see if it settles.
2. Exhaust is not spaced properly. Dealer ordered new exhaust
3. tear in headliner. Dealer ordered new headliner
4. right rear quarter panel has a damaged edge. Unfortunately the panel was painted damaged. Not sure how to handle this one.
5. ordered floor mats and cargo mats, however dealer hasn't received.
I haven't gotten into the electronics yet as I headed out of town a few hours after picking up. That will have to wait until this weekend.
Love the car!
cbboarder is offline
Old 10-14-2013, 11:21 PM
505hp
505hp's Avatar
my reverse camera stopped working and then displayed something to the effect of - service reverse camera. The problem was you couldn't bypass this grey screen with white letters to use the radio or nav etc ....it started working again later in day.
505hp is offline
Old 10-14-2013, 11:40 PM
Durnberg
Durnberg's Avatar
St. Jude Donor '13
Very similar to mine, radio wouldn't work and I didn't mention that in post 9.
Durnberg is offline
Old 10-15-2013, 07:49 AM
rickriada
rickriada's Avatar
C7 of Year Finalist (appearance mods) 2019
Torch Red Z51 VIN 2553. Has anyone had any problems with the rear hatch/window being hard to close/seat into the frame? I really have to shove/slam it downwards to get it to completely close. More often than not, I must complete the process by pushing it the rest of the way down into the frame by using one of my hands. Maybe it has to do with the latch adjustment or too much air pressure inside the car when the rear hatch is being closed and the passenger/driver windows are still up? I will bring it up to my dealer today on the way home.
rickriada is offline
Old 10-15-2013, 08:08 AM
agapsdiver
agapsdiver's Avatar
Originally Posted by rickriada
Torch Red Z51 VIN 2553. Has anyone had any problems with the rear hatch/window being hard to close/seat into the frame? I really have to shove/slam it downwards to get it to completely close. .
Instead of slamming it down, place it down gently 'til it stops, then, with a flat hand in the center of the hatch, simply give it a strong push/shove. Works for me.
agapsdiver is offline
  #33
rickriada
rickriada's Avatar
Never mind my post this AM as I found another thread where this issue (or not) is being discussed. The video on that thread by Mike Davenport is quite helpful.
Old 10-15-2013, 09:26 AM
  #34
Doccars
Doccars's Avatar
I also made the same observation. (Found if you bend your neck slightly it seems to straighten out. LOL)
Did inform the factory but have not received a response.
Doccars is offline
Old 10-15-2013, 11:07 AM
  #35
CaptRat
CaptRat's Avatar
That's what I do as well. When I had an Xpel clear bra installed I also had a piece of Xpel installed on the center of the hatch to protect the paint during closing.
Rat
CaptRat is offline
Old 10-15-2013, 02:55 PM
  #36
Bill B 1
Bill B 1's Avatar
Can you provide a link to that video here?
Bill B 1 is offline
Old 10-15-2013, 07:20 PM
  #37
post-it
post-it's Avatar
Originally Posted by rmarc7828
Vin 1537 z51 3LT. Tire Puncture.
At 210 miles the rr tire picked up a 2.5" long wheel balancing weight off the road at about 30 mph. When the weight rotated into the wheel well the weight was forced into the tire tread causing a large puncture. Wheel well was also damaged with two holes completely through.
Clearance between tire and wheel well is very small and I am concerned that those that are lowering their cars may actually be increasing the potential for this type of tire damage. Obviously I was unlucky to the tune of $425 for a new tire. Interested in hearing from others regarding this failure.
I don't like these tires. They pick up everything on the road and cut very easily. I will be looking for a Pirelli Zero Nero to replace the Michelins.
post-it is offline
To ** C7 Reported issues and resolutions thread **
Old 10-15-2013, 08:00 PM
  #38
rickriada
rickriada's Avatar
Here is the video by Mike Davenport that Bill B 1 asked for. I hope this link works for him. Otherwise, just search for his name on the search feature and you should find this then.
http://www.youtube.com/watch?v=aabTw...ature=youtu.be
Old 10-15-2013, 10:36 PM
  #39
Marcula
2nd Gear
Marcula's Avatar
Default Magnetic ride selection/PTM mode problem
I am having a problem engaging Performance Traction Management Mode. I follow the instructions in the owner's manual quoted below:
"In order to select this optional
handling mode, the vehicle mode
must be Track. Then quickly press
the TCS/StabiliTrak g button on the
center console two times. PERF
TRAC 1 - WET ACTIVE HANDLING
ON displays in the DIC."
I also found a you tube video that shows what should be displayed in the DIC.
When I try to "quickly press the TSC.." button while in Track Mode I do not get the 5 PTM modes on my DIC. Instead it I get the Traction Control Off symbol. The manual indicates that if the tire pressure monitoring system is malfunctioning PTM is not available but my system shows okay. I definitely have the option on the vehicle.
VIN 1560
Marcula is offline
Old 10-15-2013, 10:45 PM
  #40
Theo Harris
Theo Harris's Avatar
Originally Posted by Chevy Cust Svc
We'll be sure to keep an eye on this thread! Thank you for starting it. As always, if anybody would like our assistance in any way, we're only a private message away.
Sarah (Assisting Kelly)
Chevrolet Customer Care
Help Chevy Help
I only had my c7 for one full day and the windshield is cracked, dealer Len Stoler Chevrolet in Westminster Maryland is trying desperately to get one from Chevy with no success, I have been told to pick up the car and drive it with a cracked windshield as there is no ETA of a new windshield
Theo Harris is offline
