Nitrogen instead of air in tires?
are most of you putting nitrogen in tires instead of air? What are the benefits and do you do it yourself or dealer? What is the process to get it done right? I just heard that nitrogen supposedly gets you more life of tires but not sure if it is bs. Thanks
The air in your tires now is 78% nitrogen. No real advantage for most of us to use pure nitrogen but if your dealer is putting it in at no extra charge just leave it.
St. Jude Donor '11-'12-'13, '15
Here is the benefit...it is dry, air is not. It does not heat up and expand as humid air does in your tire thereby increasing the pressure as temps rise giving you more stable and consistant tire pressures. It should be provided free at your dealership...if not, I would never pay for it!!
1 Post
Moderator
If they do it free, fine. Otherwise don't bother. Our Cadillac dealer (wife's SRX) provides Nitrogen fill at no charge.
1: Short of mounting your tires in a vacuum chamber, how does the dealer or service garage get the air that was in the tire when installed out?
2: how does nitrogen repeal the ideal gas law which says given a constant volume (the interior of a mounted tire/wheel combo) as temperature increases, so does pressure? I know the nitrogen in accumulators on my airplane vary in pressure as temperature changes. The specs call for a certain pressure at a nominal temperature (usually 70 F) and then give a +/- for different temps.
Received 4,376 Likes
Nitrogen is used in aircraft tires because it is dry and moisture will not condense as the aircraft climbs into the colder air. In severe cases this condensation could collect and freeze causing the tire to be out of balance on landing. Imagine a tire out of balance at 130 knots.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Two questions:
Look up the vapor pressure of water from Wikipedeia.
Nitrogen is used in aircraft because it is not flammable. They could just as easily dehydrate regular air if you think moisture is the problem. The Ideal Gas Law still applies.
Now if you're putting water in the tire and the temperatures reach boiling point, that's a different story. But the boiling point of water in a pressurized tire is far greater than 212dF
http://www.csun.edu/~jeloranta/CHEM351/example2.pdf
Go to #7
Go to #7
