Insight to the C7Z06 & ZR1
Old 10-25-2013, 08:00 AM
  #41
simplegto
simplegto's Avatar
St. Jude Donor '11-'12-'13-'14
Originally Posted by SBC_and_a_stick
No need to get thicker walls than the 6.2L for boost, so the 5.5L is purely a loss of displacement with no gain in any other metric (except efficiency in NA forms, not the case here).
8k rpms is useless in the 2 valve head. This head doesn't flow enough up top to make any more power up there. Sure, some cams are extreme enough to make power up to 8krpm but none of the engines would be profitable with a warranty, nor would they pass emissions. The other useful bit would be variable lift and overlap, but you can't do either with GM's VVT.
My best guess on this is no and on, no on 5.5L, and no on 8k rpm.
A 7.0L is probable, and it would get me to the dealer.
Short stroke engines will spin faster and with forced induction boost makes up for displacement. Nascar runs 2 valve heads at 9500 rpm. Just a guess!
Old 10-25-2013, 09:24 AM
  #42
starchedup
starchedup's Avatar
Originally Posted by VRYALT3R3D
Because then it loses its corvette DNA.
The Corvette is a toy.....
I would veto the backseat idea. Adds more weight plus its not a STANG. Nope, Nope, Nope...
Old 10-25-2013, 10:10 AM
  #43
genv6.2gm
genv6.2gm's Avatar
my question is what does the lemans 5.5l rev to?
Old 10-26-2013, 09:16 PM
  #44
SBC_and_a_stick
SBC_and_a_stick's Avatar
I'm pretty sure LS3 and LT1 can both rev higher but if power isn't made up top there is no reason to have the higher redline. It would only increase warranty claims.
TVS modifies the torque curve very little, again no benefit to rev higher.
Nascar engines don't get driven 100,000 miles nor do they have to pass emissions with those cam profiles.
Might have changed from '08 but still...: "The life expectancy of a NASCAR engine is one race."
http://americanmachinist.com/features/machining-nascar
See also the C6.R, peak power under 6000 rpm:
http://www.corvetteracing.com/2012-specifications.shtml
Old 10-26-2013, 09:18 PM
  #45
BeaZt
BeaZt's Avatar
St. Jude Donor '14
LPE has an LT1 at 720 hp and 655 lbs of torque supercharged at 7psi. I wonder what the HiPo version will bring and then what tuners will do with it.
Old 10-26-2013, 10:24 PM
  #46
SBC_and_a_stick
I'll say 670hp. Everything I've seen so far looks like past generation engine output+30hp. Given the formulas remain the same, the 7.0 would make 535hp, and the 6.2 SC would make 610hp in low cost trim and 670hp in hi-cost trim.
Old 10-26-2013, 10:26 PM
  #47
BeaZt
BeaZt's Avatar
St. Jude Donor '14
I agree with that.
Old 10-26-2013, 10:38 PM
  #48
SBC_and_a_stick
The torque difference is large however. I don't quite get one of my experiment results, but torque seems to matter in addition to power, somehow...
With a grain of salt, as this was a hack on the Gran Turismo simulator but:
ZR1 engine>Ferrari F1 engine
even
Z06 engine >Ferrari F1 engine
in the same car shell. I even made the F1 powered shell 50lbs lighter.
For reference, the Ferrari F2007 F1 car made 700hp. Somehow even the 505hp Z06 engine powered shell beat the F1 powered shell despite a near 200hp handicap. Torque? I do believe Gran Turismo does their homework in terms of dynamics.
Old 10-27-2013, 12:28 AM
  #49
C7 4 Me
C7 4 Me's Avatar
Originally Posted by NVMYRC51
A ZR-1 is going to be difficult to pull off in this economy. Didn't the C6 ZR-1's end up getting sold at deep discounts? I am sure GM is closely watching the Viper debacle and hopefully taking notes. An American made car at that price is hard to market. Just a thought here though. What if they had a double clutch, paddle shifted, NA 427 with special track handling package; full active aero, wide body kit with wider tires, that came in under $100K? Change the rear tail lights back to round/oval whatever just not what is there now and give the ZR-1 special paint options. Playing the HP game is not where the money is at but it is where cost is at. Keep costs down, introduce the American market to an awesome paddle shift 6 or 7 speed and a car than out handles everything? I think that is where the future may lie but is it sacriledge?
I think you're lusting after a hipo C6. It might be hard to imagine, but the round tail lights arent lusted after, and they aren't coming back
I like your dual clutch transmission idea though.
Old 10-27-2013, 12:32 AM
  #50
pietro c7
pietro c7's Avatar
Received 1,157 Likes on 650 Posts
Just curious...does anybody here lusting for 600 plus horsepower version,...have actually driven the c7 in current form....if yes,team Ferrari seems to have an opening next year to second Alonso...
Old 10-27-2013, 01:01 AM
  #51
rcallen484
rcallen484's Avatar
Yeah, the new tail lights seem to look AWESOME on at least one wide bodied C7 (C7R proto)...
Old 11-14-2013, 07:36 AM
  #52
midnightbluS10
midnightbluS10's Avatar
All this ZR1 TALK...I'm betting that they axe the ZR1 completely. Its just not supported enough to warrant all the cubic $$$ spent on that program.
Old 11-14-2013, 07:53 AM
  #53
#1c6
#1c6's Avatar
the z07 and the zr2 with be like the z28, track cars. thats my guess.
Old 11-14-2013, 08:38 AM
  #54
Jasil
Jasil's Avatar
I expect only 1 hi performance model not two! Similar displacement to the stingray and low pisi roots based FI nothing earth shattering imo. Just hope it puts out around 650-670hp.
Old 11-14-2013, 09:48 AM
  #55
genv6.2gm
genv6.2gm's Avatar
how much is spent and how much is lost are two different things. Preliminary testing of systems for the C7 were used on that car. A lot of the R&D cost were going to be spent anyway. With the direct costs that would be spent anyway I would be curious how much extra a ZR1 costs GM not factoring any R&D that was factored for the C7 and it's possible HiPo versions.
Old 11-14-2013, 09:53 AM
  #56
travisnd
travisnd's Avatar
Rumormill says they've retained the ZR1 name and that there will be only one performance model for now. That would jive with the original Jalopnik leak showing the ZR1 badge in the side cove. The spy shots all jive with the original Jalopnik render i.e. front splitter, rear cooling inlets on the rockers etc. Only thing is the mules are clearly widebody vs. the Jalopnik render being the standard C7 width.
Old 11-14-2013, 10:23 AM
  #57
LT1xL82
LT1xL82's Avatar
At least 1 hi-po model for 2015.
Your description of motor is highly probable.
Regardless of the motor configuration, it will be interesting if the car is marketed as Z06 "ish" (i.e. street able track car) or as ZR1 "ish" (i.e. heavily optioned King of the Hill trac able street car). Either way, one would think that it will be a wide body/wheels/tires with bigger brakes likely.
Old 11-14-2013, 01:22 PM
  #58
sam90lx
sam90lx's Avatar
Skank says we will see a NA and FI model....he is in the know! ( At least I hope he is )
Old 11-14-2013, 03:48 PM
  #59
RandomTask
RandomTask's Avatar
I've said this before and I'll say it again.
The new motor will share more with the LT1 did than the LS7 or LS9 shared with the LS3.
You have to remember, when GM built those motors, they had to go use exotic materials which drove costs waaaay up. Custom valves, custom pistons, custom cranks, custom rods, etc. GM is trying to keep costs down with this setup.
Second, in regards to turbo's, you guys have to realize packaging and service is a huge deal with these. On turbo setups, even aftermarket stuff, its expensive, and the packaging is a HUGE pita; not only do they have to squeeze the turbo's in there, but they also have to manage to install 2 air to air intercoolers vs a SC'd setups single air to liquid.
Also, compound all of this with a computer controlled boost controller, people would be buying a $300 mail tune, cranking the boost way up, popping motors, setting everything back to stock, then bitching at GM to fix it under warranty. A SC'd variant is more of a rigidly controlled boost setup. That is, it takes a lot more effort to increase the boost on a SC car.
Further evidence the new car will NOT be turbo, just look at the old pictures of the C7 prototype dash:
That's a PD blower icon, not a turbo.
The current limitation on the new motor under development, which is a SC'd 6.2L, are the rod bolts. They stretch, things break. New setup, expect ~585HP.
Quick Reply: Insight to the C7Z06 & ZR1
