Tail light squeak eliminated.
Old 11-08-2013, 09:48 AM
runutzzzzz
Support Corvetteforum!
runutzzzzz's Avatar
Default Tail light squeak eliminated.
Well, most of it.
Went out to wash my car this morning and got super annoyed with the squeak. After I was done washing it I looked into what was causing the squeak.
On my car it was the "Fangs" on the tail light bezel. You can actually press up on it and see it rubbing the tail light.
I took it off and used a die grinder to file it down.
Put it back on and it's gone! Well at least most of it. It's still rubbing on the bottom outer edge of the tail light but I'm not going to file that down. I'm going to go get some felt tape and put a small piece on that.
About 15 minutes total to do both.
Old 11-08-2013, 10:07 AM
Pat Salerno
Pat Salerno's Avatar
How did you remove the tail Light trim?
Pat
Old 11-08-2013, 12:22 PM
craig04c5
craig04c5's Avatar
Very good. I am sure a lot of C7 owners will be doing this. Maybe even GM will see your thread and do something similar before putting them on the car.
Old 11-08-2013, 01:17 PM
runutzzzzz
runutzzzzz's Avatar
Pat
There are clips that hold it in all around. I'll add pics of the trim so you see where they are. I used a towel and a plastic pry bar to "spread the tabs apart.
Hopefully gm fixes it. It's very simple to do. They need to just revise the mold so it doesn't interfere.
Old 11-08-2013, 01:18 PM
Glen e
Glen e's Avatar
Thanks...be looking real close to try and find the tabs....I want to paint them.....
Old 11-08-2013, 01:29 PM
TTRotary
TTRotary's Avatar
Squeeky Mascara
Old 11-08-2013, 03:39 PM
SCM_Crash
SCM_Crash's Avatar
Interesting... Wouldn't using some felt (or some other material) around the area that is rubbing work as well?
Old 11-08-2013, 06:04 PM
runutzzzzz
runutzzzzz's Avatar
Yes it would.
I considered using felt tape but I just know that it would fall off eventually as well as you will be able to see it if you look for it. Not that anyone is going to go stare at the top of your tail lights but I know it's there. LOL When grinding it down you won't be able to tell a difference in how it looks on the car.
Old 11-08-2013, 06:35 PM
SCM_Crash
SCM_Crash's Avatar
Originally Posted by runutzzzzz
Yes it would.
Funny thing, though... People HAVE stared at my tail lights like that. When I take the car to shows, believe me, people seem to get really comfortable and close with the car and its details.
Old 11-09-2013, 03:47 AM
HDBADDOG55
HDBADDOG55's Avatar
"There are clips that hold it in all around. I'll add pics of the trim so you see where they are. I used a towel and a plastic pry bar to "spread the tabs apart."
Please post those pics.Great thread
Old 11-09-2013, 01:53 PM
runutzzzzz
runutzzzzz's Avatar
Posted pics. I "popped" the middle one on top first then went towards the center of the car then once those popped I gently just pulled the whole bezel out and the clips popped pretty easy.
I warn you, be careful with what you use to pry the bezel out. You can mar your paint on the rear bumper or scratch your bezel.
Old 11-11-2013, 01:07 PM
Periokid
Periokid's Avatar
St. Jude Donor '06
I am not sure I understand where to grind.
Old 11-11-2013, 01:29 PM
rcallen484
rcallen484's Avatar
That's what she said....
Old 11-11-2013, 10:02 PM
runutzzzzz
runutzzzzz's Avatar
The "Fang" part. The part that looks like a V in the first picture.
With it still on the car you can see it touching your taillight.
Old 11-11-2013, 11:48 PM
Mike O'Daniel
Mike O'Daniel's Avatar
Shes squeakin'? Nothin' that a good punch in the tail pipe won't cure.
To Tail light squeak eliminated.
Quick Reply: Tail light squeak eliminated.
