C7 Z51 Gearing
Moderator
Gear Ratios:
...........................A6....Z51A6.. ...MN7...Z51MN7
First gear............... 4.03 .. 4.03 .. 2.66 .. 2.97
Second gear.............. 2.36 .. 2.36 .. 1.78 .. 2.07
Third gear............... 1.53 .. 1.53 .. 1.30 .. 1.43
Fourth gear.............. 1.15 .. 1.15 .. 1.00 .. 1.00
Fifth gear............... 0.85 .. 0.85 .. 0.74 .. 0.71
Sixth gear............... 0.67 .. 0.67 .. 0.50 .. 0.57
Seventh gear............................. 0.42 .. 0.48
Reverse.................. 3.06 .. 3.06 .. 2.90 .. 2.90
Axle ratio............... 2.56 .. 2.73 .. 3.42 .. 3.42
Overall ratios:
...........................A6....Z51A6.. ....MN7...Z51MN7
First gear...............10.32 ..11.00 .. 9.10 ..10.16
Second gear.............. 6.04 .. 6.44 .. 6.09 .. 7.08
Third gear............... 3.92 .. 4.18 .. 4.45 .. 4.89
Fourth gear.............. 2.94 .. 3.14 .. 3.42 .. 3.42
Fifth gear............... 2.18 .. 2.32 .. 2.53 .. 2.43
Sixth gear............... 1.72 .. 1.83 .. 1.71 .. 1.95
Seventh gear............................. 1.44 .. 1.64
Overall ratios:
Moderator
Gear Ratios:
...........................A8....Z51A8.. ...MN7...Z51MN7
First gear............... 4.56 .. 4.56 .. 2.66 .. 2.97
Second gear.............. 2.97 .. 2.97 .. 1.78 .. 2.07
Third gear............... 2.08 .. 2.08 .. 1.30 .. 1.43
Fourth gear.............. 1.69 .. 1.69 .. 1.00 .. 1.00
Fifth gear............... 1.27 .. 1.27 .. 0.74 .. 0.71
Sixth gear............... 1.00 .. 1.00 .. 0.50 .. 0.57
Seventh gear............. 0.85 .. 0.85 .. 0.42 .. 0.48
Eighth gear.............. 0.65 .. 0.65 .. .... .. ....
Reverse.................. 3.82 .. 3.82 .. 2.90 .. 2.90
Axle ratio............... 2.41 .. 2.73 .. 3.42 .. 3.42
Overall ratios:
First gear...............10.99 ..12.45 .. 9.10 ..10.16
Second gear.............. 7.16 .. 8.11 .. 6.09 .. 7.08
Third gear............... 5.01 .. 5.68 .. 4.45 .. 4.89
Fourth gear.............. 4.07 .. 4.61 .. 3.42 .. 3.42
Fifth gear............... 3.06 .. 3.47 .. 2.53 .. 2.43
Sixth gear............... 2.41 .. 2.73 .. 1.71 .. 1.95
Seventh gear............. 2.05 .. 2.32 .. 1.44 .. 1.64
Eighth gear.............. 1.57 .. 1.77 .. .... .. ....
Overall ratios:
maho6246 (08-31-2020)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Here is a spreadsheet you can use to change to any ratios or tire sizes you want to look at...
The macro buttons at the top will insert the right tire size, gear ratios, and rear end ratio as best I know...
CorvetteRPM_Speed_Calculatormacro2.xls
Attachment 47834252
Attachment 47834252
It also appears to only have 6 gears displayed, rather than the 7 on the C7.
It also does not have the 20" rear tire listed on the bottom of the sheet but it does function and give data for the 20".
I'm afraid It may need a full rework. I'll play with it and see if I can make it work.
Elmer
I know I may have missed a few things. I was just taking a spreadsheet I had for my C5 and adding macros for the C7.
The 20" tires are in there for Z06 and Z51 calculations, but I did not bother to create a table, and I figured the speed in 7th was pointless since it would be limited my other factors such as aerodynamic drag...even in 6th, we know it cannot go over 200mph.
You are right that I did not bother to add info for automatics....
Gear Ratios:
Overall ratios:
Overall ratios:
49, 71, 102 147, then aerodynamics most likely become the limiting factor.
