Front tire rub
Old 12-09-2013, 02:44 PM
camaro01octane
Cruising
camaro01octane's Avatar
Default Front tire rub
Anyone else have issue of there front tires rubbing. Whenever i am driving and if i stear to much my front tires rub. It doesnt happen when i am on highway or city but if i am just barely driving and turn my car to much i can feel my tires rubbing.
Old 12-09-2013, 02:45 PM
camaro01octane
Cruising
I have a 2014 z51 corvette.
Old 12-09-2013, 02:46 PM
Glen e
Glen e's Avatar
normal
http://forums.corvetteforum.com/c7-g...is-turned.html
Old 12-09-2013, 02:52 PM
Glenmcp
Support Corvetteforum!
Glenmcp's Avatar
Tight turns backing out of a driveway or parking space or wherever is going to cause skipping/hopping. Some of it is because of the "Ackermman Effect". And some is do to the sticky tires. There are a few threads about it on the CF.
canyon vette
canyon vette's Avatar
I only feel it while backing up. It's called tire chatter and is normal based on the new suspension geometry.
Old 12-09-2013, 03:24 PM
camaro01octane
Cruising
Default tire
I fell it backing up, but i also feel my front tires rub whenever i am turning out of my driveway or when i am going 5-10 mph and having to take a sharp curve, that cant be normal.
Old 12-09-2013, 03:31 PM
Glenmcp
Glenmcp's Avatar
It is unlikely that your tires are rubbing on the body or frame. They are most likely skipping on the ground which is normal. Take the car to your dealer if your are worried about it.
Old 12-09-2013, 04:03 PM
GSIRM3
GSIRM3's Avatar
I think it is completely normal for the wide, high performance tires. All of my recent 911's have done the same thing, usually only when cold however.
Old 12-09-2013, 04:08 PM
RocketGuy3
RocketGuy3's Avatar
Assuming you haven't dropped the ride height significantly or haven't put oversized wheels/tires on there, then you are not rubbing, the tires are just hopping. And yes, it is completely normal.
Old 12-09-2013, 04:12 PM
neatwheels
neatwheels's Avatar
Default Tires Hopping at Low Speed / Severe turning
Normal! Its a front steer vs rear steer ackerman geometry. Doesn't hurt anything.
Normal turns and highway it won't happen.
Old 12-09-2013, 05:35 PM
Cruiter
Cruiter's Avatar
On order: Torch Red Z51
RE: tires rubbing. That shouldn't happen unless the car has been lowered, if so you went too far. My car settled after about 1000 miles and didn't need to lower it. Or putting on non OEM wheels & tires of the wrong size could cause it as well.
Old 12-09-2013, 05:38 PM
shaan
shaan's Avatar
NORMAL!!!!!!!!!
Old 12-10-2013, 06:04 AM
camaro01octane
Cruising
Default thanks
Thanks very much, i finally joined this forum but been doing alot of reading on it. I never seen anyone talk about it. I had a 2010 camaro ss and it never did that and it had wide tires also. I never lowered it but i feel alot better now knowing this is normal. It did scare me sometimes. I love this car. My only complaint would be it didnt have the nice lighting inside the car that my camaro had but other then that its a dream come true.
To Front tire rub
Quick Reply: Front tire rub
