Lowering on stock bolts - Instructions and Photos
Received 9,512 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
2015 C7 of the Year
My pleasure!
Headlights seemed to be fine for the short test drive last night. With regard to alignment, the research I did suggested that it's good to have the alignment checked, but that in most cases the alignment was still within proper specs after lowering on the stock bolts. I'll let you know once I have my alignment checked.
I just want to add that if Chevy put them bolts there for this purpose it probably is NOT an issue for alignment but I'd like to know before I do it.
2015 C7 of the Year
Thanks. I appreciate your work. I lowered my RT Challenger lower than the SRT8 Challenger and then nobody could come up with the correct specs to align it. I certainly don't want to get into that problem again. I go through tires (especially summer tires) fast enough anyway.
The following 2 users liked this post by jagamajajaran:
Jet Vet (11-30-2015),
Wandering Scot (07-24-2018)
Received 1,974 Likes
Actually the adjustement is really so minor none of the above concerns are really an issue.
What I was surprised with was the stock setting where very inconsistent. I measured the before and after "distances" from about 6 different aspects. Looked to me the factory adjustments where very random........... like each corner was taken from a different parts box stuck on and never adjusted.
Even after I dropped it all the way there is no consistency in the heights.
So my conclusion is drop it and forget it.
SterlingDrive (12-10-2016)
thanks you for the info... going to tackle this project once my new wheels arrive and painted splash guards : )
When I lowered my Challenger back then I put in new springs all around and the car actually continued to get lower by an eighth to a quarter of inch over the next few months. But that was with brand new springs.
Thank Jag for the great writeup and excellent pictures! Those are great contributions that will help many of us here including myself! I am eagerly awaiting the arrival of my new C7 which should be here in the next 10-14 days and this will be one of the first things I do to it!
Thanks again for taking the time to document the procedure. While it's the same process as the C6, documenting it for the C7 will alleviate any questions others might have.
This should be Stickied at the top of the forum!
2015 C7 of the Year
You bring up an interesting point. These cars are so new that the suspension and springs may still be settling. I think you should continue to take these measurements for a few months and keep it set so the car is the same heights from side to side. That may be why the factory doesn't bother to set them during installation.
#33
and no I don't care about cooling or aerodynamics with the dam gone....
#34
great advice...people get too **** about these things..the base car does not significantly drop at all on it's own....this is a "just do it all the way down mod" - I took off my front air dam too and have no scrape whatsoever on any parking ingot (car is still higher) or speed bump. I like it a lot better..
#35
disclaimer: I'm in Florida so it might keep the car cleaner in the north, not my situation...
#36
Going from a c6 GS even with the C7 down on the bolts its like an SUV...... all my scraping issues are gone......... places I use to have to watch out for with the C6.
Can't imagine a ZR1 with a the lower splitter..........
#38
2015 C7 of the Year
I turned them until they could turn no more. That is the lowest setting. From there, you can measure the height and make adjustments if the lowest setting isn't equal on each side of the car.
#39
You don't happen to have before and after pics, do you? Would have loved to see how much a difference the procedure made.
#40
2015 C7 of the Year
