Tire Pressure
Tire Pressure
Z51 folks, what tire pressure are you running on the street? Mine came delivered running 34 psi all around. The manual and the door sticker calls for 30 psi cold. I set mine at 30 cold; it rides better but my TPMS is in alarm for both rear tires. That sure doesn't make sense, especially when the manual recommends dropping the pressure to 26 for track use.
Anyone else seeing this happen?
Joe
Joe
Two things come to mind. Are you using a good tire pressure gauge and have you driven the car for several miles to see if the pressure warning goes away with the 30 PSI setting?
Congrats on the Stingray.
I use a good gauge and set mine at 30 but it was 30 degrees. No warnings yet. That is with 4 outings in the car due to weather.
I would suspect that at 26 during track use that the pressure and temperature will rise quickly. It was not unusual for me to see pressures rise from 32 to mid 46 during a 30 minute session. Keep in mind that you will lose approximately 1 psi for every 10 degree drop in ambient temperature.
Ken
Ken
Wonder what other systems that affects?
Thanks. That's what I would expect too. Looks like dealer time…..bummer.
Ken
Ken
I am taking my C7 to its first autocross in two weeks. I am surprised at the 27 psi recommendation (which, by the way seems to be only for the Z51 per Sec 9-5 of the manual). I get it for track events, but have my doubts about brief autocross runs. I am new at this. Your thoughts?
Dave
Not sure about the C7 yet as I'm still waiting on my order, but I have another vehicle that will give a low pressure warning when it sees a certain % drop in PSI. The way to reset it on that vehicle is drop the PSI below the desires pressure by several PSI and then inflate the tire to the desired PSI. (ie, take it down to 20PSI then inflate it to 30PSI)
It may not work this way on the C7 but if it saves a trip to the dealer it may be worth trying.
Then it comes right back on again.
Definitely a trip to the dealer. Sounds like at least one sensor, or possibly the whole system, has a problem. If the car says 30psi and still gives you a warning, I'd suspect the system. On my C5 and C6s, you have to get below 25psi to get a warning. Haven't seen the warning on the C7 yet.
I don't know about on the C7, but on a C6 Z06 it was discovered that running it without the TPMS caused drivability issues like being unable to turn off active handling and maybe even a loss of power, presumably to keep you from trying to drive 100 mph on a flat tire.
Dealer appointment for Monday.
So I just received the monthly on star maintenance report and it says my air pressure needs immediate attention. Get this: It shows my air pressure correctly (as expected) but states recommended pressures at 36 front, 41 rear! That would sure clear the alarm but take all sidewall give out of it. Way too much pressure for these tires.
Anyone else received an on star report that says that?
Had my Z51 for 4 months, then yesterday my TPMS warning light came on, show's all 4 tire pressures in order, lowest was 28 highest was 30.
What did the dealer say/do about your car's TPMS issue?
Received 2,379 Likes
First, get a trusted gauge and compare the readings to the TPMS readings. You will know the actual pressure and can adjust accordingly.
Second, check to make sure there isn't a TPMS reset function in the menus to set current pressure to the baseline (lots of cars have this now).
Third, I fully intend to run 35psi all the way around to start and then recheck after a drive to ensure a 10% increase in pressure in front and 20% increase in back. I can adjust my pressure down if it doesn't make it and up if it goes over.
You set cold psi to achieve an expected hot psi except that it is easier to recommend a cold psi in a book because 99% of people aren't going to be troubled with measuring and adjusting hot psi. When you drive your tires are hot, not cold. Who cares what the cold temps are as long as they get to the right hot temp (in a reasonable amount of time).
Hot temps are going to vary based on drive time, road surface, ambient temps, street vs track, etc. Use your car how you normally use it (whether it is going to starbucks or hitting the canyon roads or Road Atlanta) and check your pressures and adjust hot.
Anywhere from 30 to 40 will "work fine" for street use. Higher pressure will give a touch better mileage, faster turn in, etc, lower pressure will give a touch better ride comfort, slightly faster operating temps, etc. Street driving hardly pushes pressure requirements.
Do you folks have a valid reason beyond your own opinion for deviating from 30psi cold? For instance, when I switched to Michelins on my C5, I found that the rears had excessive wear in the center of the tread at 30psi, so I lowered it to 28. Kept the fronts at 30 because they were wearing evenly.
I figure if the Corvette engineers specify 30psi cold, they intend for the car to be at 33-35 psi hot. Why do you think differently?
