Where is the battery?
Stupid question but can find a picture of where the cars battery is - just the positive and negative poles - thanks - its in the back somewhere like my 79 vet but what if you need to replace it is the a hatch of some sort ? found online manual is under the carpet a hatch wow never expected this on a c7
manual link
http://www.chevrolet.com/content/dam...14corvette.pdf
manual link
Moderator
Page 10-65 of the Owners Manual
The battery is under a battery cover
in the hatch/trunk area on the
passenger side under the carpet.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
C6 Z is also in the rear
Kman6745 (04-29-2023)
manual link
manual link
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
My manual states quite specifically to do the jumping of the battery directly at the rear located battery and that is exactly what I will do if the need arises on my car.
Elmer
My 2014 manual does not say to use the engine bay leads to jump the car. The gauge of the wire is too small to carry that high of an amperage.
Elmer
Elmer
The .75 amp maximum for my tender should not be a problem.
Yes, but it still sounds like a good location for a permanently connected cable for a battery tender. Right now I've got my cable hooked up in the back directly to the battery so the AC power cord has to go either out the back hatch or out the passenger side door and then close the door or hatch on it. I've never particularly liked that. But from the posts under the hood a cable could be run to the front grill work and hidden under the hood when not in use.
The comment was about reply #7 & #8 and jump starting from the under hood connection. I was trying to counter those two comments as NOT acceptable to do. I also have my battery tender attached to the front posts under the hood. I have the magnetic connector on the front of my car and if I forget to disconnect the maintainer, it will disconnect and drop to the floor as I back out of the garage.
http://www.ls2.com/forums/showthread...hlight=battery
Elmer
