Carbon Fiber
Old 01-21-2014, 10:13 AM
RayTony
Cruising
RayTony's Avatar
Default Carbon Fiber
Does the Carbon Fiber roof require any special treatment to clean and polish?
Old 01-21-2014, 10:33 AM
SilversledC7
SilversledC7's Avatar
The "exposed" carbon fiber roof is most likely clear coated. I doubt the resin system is a polyester and is most likely epoxy which is not UV stable and requires a clear coat. You should be able to clean, polish and wax it just like any body panel.
If the roof panel were more delicate, they would mention it in the manual.
Old 01-21-2014, 10:58 AM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,074 Likes on 6,173 Posts
The "exposed" carbon fiber roof is indeed clear coated - with a very expensive UV inhibitor additive. Just treat it like any other clear coated panel.
Old 01-21-2014, 11:48 AM
Zymurgy
Moderator
Zymurgy's Avatar
The UV additive was reported to cost $60,000 per gallon. The clear coat with the additive was reported to cost $2000 per gallon.
Old 01-21-2014, 12:12 PM
craig04c5
craig04c5's Avatar
Makes you wonder how many roof panels can be done for that $60K?
Old 01-21-2014, 01:53 PM
Stingray Al
Stingray Al's Avatar
Originally Posted by zymurgy
the uv additive was reported to cost $60,000 per gallon. The clear coat with the additive was reported to cost $2000 per gallon.
wtf ?????
To Carbon Fiber
Quick Reply: Carbon Fiber
