Scratch on my C7 windshield. How do I remove it?
I noticed a scratch on my windshield. There must of been some type of granular material under the wiper. It is a half moon on the drivers side. I just washed the car but I can still see it. It is not deep at all, I can hardly feel it when i rub my fingernail over it.
Any suggestions how to get it out?
I was going to put some wax on my buffer and buff it a bit
let me know
Al
let me know
Al
toothpaste, takes awhile and rube hard. But it will work.
If you can feel it, probably can 't polish it out. There is a pumice compound available at glass shops that you can purchase. The pumice is mixed with water into a paste then the hand polishing begins with a special polishing block. Takes a lot of rubbing.
Same thing...
Hello, I just noticed the same exact thing on a my car that is like six weeks old, never been in the rain, and I used the wipers once with spray. A "tracing" on the glass that I have never seen on any Corvette or any car I have ever had. I examined the wiper and found nothing.
I am very frustrated with GM in general and now this mess.
May I ask if the OP (Stingray Al) got the scratch out without replacing the windshield? Or what happened?
I am afraid to use the wipers at this point.
Thank you.
Thank you.
That sucks. Wonder how debris got caught on the wiper blade and caused a mark. My truck sits out at the airport for weeks, dirty as all get out, hit the window washers and never a mark. Might as well use the wipers, may even polish the mark? Sometimes I think we are so careful that in the end just more damage is seen. Normal driving and wiper use probably would polish defect out and you would never know it had happened. I have seen light wiper abrasion on driven cars.
I have about 10 small 2" scratches on my windshield too. There is no consistent pattern and I can't figure out how they got there.
I have had the same problem - half moon scratch- outside edge of the wiper on the drivers side with only a few hundred miles on it. I had only driven it in the rain once- slowly at a Christmas parade. I took it to the dealer since the car was so new but was told Chevy does not cover windshield scratches - I had them look at the wiper blade /arm for any abnormality but they found none. We should watch and see if this becomes a more common occurrence - I have a owned a lot of cars, driven in a lot of rain and never had this happen in 50 years -so I am suspicious. I could feel it - It would not polish out and I had to have a new windshield put in. If you do the same, be sure to have them hide your radar detector power wire in the trim - they have great access with the glass out.
windshield wiper scratch/windshield replaced
After reading a ton on the internet, I think replacing the window or living with it are the only two realistic options. May I ask, when you had your window replaced, was that a HUGE deal or, is it something that can be done without causing additional problems (leaks, etc.)? I have to find something to worry about :-) thank you.
It was an all day job according to the glass guys - they said there are 15 wires coming out of the mirror assembly. I was not sure if they were accurate or just guessing. Anyway , they did a great job - it looks as good as new , no leaks , no wind noise, no left over glue spots - it looks just like it did when I took delivery. I am just apprehensive about using the wipers now - especially after hearing that others have experienced the same thing. I have zero proof but I just have a gut feeling something other than a foreign object on the driverside wiper - caused that scratch. If it happens again, I doubt my insurance will cover it twice. I am going to stay tuned to the forum to see if more reports show up.
No one could get the scratch out - the quote from every attempt was if you can feel it with your finger nail, it will not be correctable. I found that to be true so I had to go with the replacement option because the scratch was annoying and it killed me to have it on my brand new car.
The exact same problem
I just had the exact same problem. 1,300 miles on my VY C7 and I have a half moon scratch on the drivers side. I can feel it with my fingernail.
This was only the first or second time that I have used the wipers. I can't remember. My car was spotless and I got caught in the rain on I95 in GA.
These three identical scratch situations makes one wonder if there is some design issue with the blade. I wonder how many cars nationwide have experienced this. This blanket statement by GM that they don't cover windshield scratches is very arbitrary and gives them no way to keep track of how many times this is happening.
Received 1,974 Likes
I have a scratch in my back window and with the tint man it bugs me. Took it to 2 glass places...both said they could make it better but can't get rid of it....you can feel it with your finger.
I took some scratch remover and it did not do much. But I have an old can of rubbing compound .... real aggressive stuff. I gently tried some of this and it worked pretty good. Have 20 % tint in the rear window so it really showed. I'm happy enough with it no need to do more.
