Z51
It includes larger 19 " front and 20 " rear wheels, dry sump oil system, Electronic Limited Slip Differential, larger front brakes, black calipers, different shocks, springs and stabilizer bars, differential and transmission cooling, Aero Package, Michelin® Pilot Super Sport ZP tires, HD Cooling, Slotted Brake Rotors and performance gear ratios.
If you scroll down this page roughly 2/3 of the way to the bottom, you'll see complete details.
http://www.chevrolet.com/corvette-stingray.html
Moderator
From the online order guide:
Online Order Guide
Z51 Performance Package, includes (J55) performance brakes, (J6A) Black-painted calipers, slotted brake rotors, (Z52) dry sump oil system, (FE3) Z51 performance suspension, specific shocks, springs and stabilizer bars, (XFJ) P245/35ZR19 front and P285/30ZR20 rear tires, (Q7S) Silver-painted aluminum, 19" front and 20" rear wheels, performance gear ratios, (G96) Electronic Limited Slip Differential (eLSD), (KNR) rear differential cooler, transmission cooling and an Aero Package
So true!
The Z51 Performance Package (available on 1LT, 2LT or 3LT), elevates Corvette Stingray to its top performance level. This package includes:
larger 19-inch front and 20-inch rear wheels
dry sump oil system
larger front brakes (13.6 inch vs. 12.6 inch) with black calipers
unique Aero Package that reduces lift for high-speed stability
Michelin® Pilot® Super Sport® ZP summer-only tires (DISCLOSURE) that are aggressively tuned to provide outstanding handling, grip and road-holding capability
available Magnetic Selective Ride Control and Performance Traction Management
HD Cooling
Performance Gear Ratios
Z51
dry sump oil system
HD Cooling
Z51
The Z51 wheels are also of a differing (some say better looking) style. Standard is a 5-split spoke style and come in Silver, or optionally Chrome or Black.
There is also an optional Torque style wheel for the Z51.
OP, I strongly recommend you check the several posts about the magnetic selective ride control that is available as an option with the Z-51 package. Consensus is it is worth it if you can afford it but not unanimous!
So true!
dry sump oil system
HD Cooling
Z51
dry sump oil system
HD Cooling
Z51
Best upgrade bang for the buck--get the Z51 if $$ permits
