TSB for Dim Dash Light
There have been previous threads concerning the dash lights not becoming brighter during Day to Dusk time frame. I have an appointment to have the rear end fluid checked, I would like to get this problem fixed.
NHTSA: Action Number: 10054480 Service Bulletin Number: 360600
Report Date:
Dec 01, 2013
Component:
Interior Lighting
Summary: Gm: the instrument panel lighting may be too low and can not be adjusted to a brighter setting. A software updated has been released to address this concern. *js
2014 Chevrolet Corvette Interior Lighting Service Bulletin 360600
Report Date:
Dec 01, 2013
Component:
Interior Lighting
Report Date:
Dec 01, 2013
Component:
Interior Lighting
Thanks.
Moderator
Service Bulletin No.: PI-1135
Component(s): POWER TRAIN
NHTSA ID Number: 10054489
Manufacturer: General Motors LLC
SUMMARY:
GM:SOME VEHICLES MAY DISPLAY A SERVICE REAR AXLE MESSAGE. DTC C0407 MAY BE SET BECAUSE THE CONNECTOR ON THE PUMP MOTOR IS NOT SEATED PROPERLY. *JS
Service Bulletin No.: PI-1101
Component(s): INTERIOR LIGHTING
NHTSA ID Number: 10054480
SUMMARY:
GM: THE INSTRUMENT PANEL LIGHTING MAY BE TOO LOW AND CAN NOT BE ADJUSTED TO A BRIGHTER SETTING. A SOFTWARE UPDATED HAS BEEN RELEASED TO ADDRESS THIS CONCERN. *JS
NHTSA only lists two Service Bulletins:
SUMMARY:
SUMMARY:
SUMMARY:
SUMMARY:
I was told that there would be an update for the center console by the end of February. I don't guess you've heard anything on this one?
I’m sorry to hear about your concern with the dash lights. I cannot guarantee the outcome but I will definitely look into this for you if you’d like. Let me know if you would like us to reach out to the dealer on your behalf, otherwise, keep me posted after your appointment. If you do want me to look into this please private message me your contact information, the VIN/mileage, and the dealership name/location. I will be looking forward to your response.
Jennie R.
Chevrolet Customer Care
Depending on the build date and options, you could ask your dealer to look up:
PI0917C, Brake squeal or squeak noise intermittently on initial brake apply. (Feb 3, 2014)
PI1159A: No XM audio, rear view camera issues, favorite stations stored twice and / or disappear. (Jan 28, 2014)
PI1148: (Z51 only) information on front lower air dam revision. Some earlier Z51 models were shipped with the outer front air dams not trimmed back as intended. This blocks airflow to the brake air deflectors on the lower control arms. The bulletin gives measurements to cut several inches from the dams and trim to an angle for better appearance. (Z51 models do not have the center air dam section)
