How to remove stock manual shift knob?
How to remove stock manual shift ****?
I would like to remove the stock manual shift **** and replace with an after-market **** but i am having difficulty removing the stock ****.
It is my understanding that all that needs to be done is to twist the ring below the **** (shown - silver ring between boot and ****) counterclockwise for a quarter turn and the **** will release.
Mine will not budge, and I an afraid to force it.
Does anyone have a suggestion or recommendation?
Thanks in advance.
Thanks in advance.
If it's like the C6, it's done like this:
http://www.mgwltd.com/corvette_short...allation.shtml
Look at the beginning of the "C6 Console And Shifter Removal" video.
When you twist the ring counterclockwise, the **** does not release, just the ring will slide down...
which allows access to set screw on the ****.
