A little help before I do something stupid
Old 03-06-2014, 02:48 PM
PUGPROUD
PUGPROUD's Avatar
Default A little help before I do something stupid
Bought a red push button ignition switch for my C7 but before I do something stupid how do I get the stock one out ? The new one appears to snap in but not allow it to be pulled back out. Assuming OEM one the same not sure how to remove it. Can anyone help ?
Old 03-06-2014, 03:11 PM
slief
Support Corvetteforum!
slief's Avatar
I could be wrong but I have a feeling you may need to pull the dash out to get it out safely. I wish I would have paid attention to that part when I did my dash swap so I could give better advice.
Old 03-06-2014, 03:44 PM
PUGPROUD
PUGPROUD's Avatar
You may be right. On the parts company web site who sold it to me it
says "simply remove your existing button" but provides no instructions
...which alone should have been a red flag I guess.
Old 03-06-2014, 03:49 PM
onthebottom
onthebottom's Avatar
Whatever you do, film it for the greater good.....
Old 03-06-2014, 03:50 PM
slief
slief's Avatar
I may be able to give you an answer shortly. There is a C7 at my buddies shop getting a bunch of Apsis stuff installed including the Apsis CF dash. I may be swinging by there in a little bit. If I do, I will take a look at the starter button and see if it's removable from the front. While it may snap in through the front, you would need a pocket knife or something thin but sturdy to pry it out. I am waiting for them to call me back as they were waiting on one small piece to arrive from Apsis before they install the dash. If I make it over there today, I will update you in about 2-3 hours.
Old 03-06-2014, 04:43 PM
PUGPROUD
PUGPROUD's Avatar
Thanks...
Old 03-06-2014, 04:44 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
your not going to be able to just pop it out and wire in the new one, thats for sure.
Old 03-06-2014, 05:23 PM
PUGPROUD
PUGPROUD's Avatar
No wiring necessary...its a plug in type switch.
Old 03-06-2014, 05:56 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
did i say wire? i meant plug.
Old 03-06-2014, 06:07 PM
slief
slief's Avatar
Ok, the button can be popped out but you will need to access the back of the button. Remove the lower panel that covers the underside of the steering column. Once you have that out, you will be able to access the back of the button to remove the plug & from there you should be able to push the button out of the dash.
Old 03-06-2014, 06:40 PM
PUGPROUD
PUGPROUD's Avatar
Thank you...much appreciate !
Old 03-06-2014, 09:24 PM
Callihan
Callihan's Avatar
pictures would be great!
To A little help before I do something stupid
Quick Reply: A little help before I do something stupid
