Black Z51 rims and brake dust
Old 03-10-2014, 12:34 PM
BADA BING
BADA BING's Avatar
Default Black Z51 rims and brake dust
Is it me or do I notice it more now that I have black wheels but the brake dust on the c7 is much greater than my c6.... at just driving 20 miles I noticed a decent amount of dust on the rims....
so my question is I like to use a duster and keep up with keeping the dust off the car when I do drive it on a nice day and will dust it periodically during the time I have it out to keep it looking nice and shiny from the road dust.
For the rims, I used a microfiber towel clean to dust the rims but then started to think that with the black and brake dust it may cause them to see scratches since they are black.... maybe use a quick detailer spray first but still would be afraid of scratches on the black.... anyone have recommendations between washes to dust the rims without scratching them?
Old 03-10-2014, 12:51 PM
Glen e
Glen e's Avatar
Google Cquartz or Opti Coat 2.0....
Or the cheaper way is a polymer sealant....like nufinish or Rejex....
All of them make brake dust hose off.....
Old 03-10-2014, 01:58 PM
ATX-C7
ATX-C7's Avatar
Originally Posted by Glen e
Or the cheaper way is a polymer sealant.. Rejex....
x2. Works great on rims
Old 03-10-2014, 04:26 PM
Process Black
Process Black's Avatar
I went the polymer sealant route and it's been working very well.
Also, I've been using AMMO Plum Wheel Spray to attack the brake dust prior to going at them with soap and microfiber. It helps dissolve the dust particles and helps lift them away safely.
The key thing is to remember to treat your wheel's finish as you would your body's paint.
Old 03-10-2014, 04:27 PM
jokerdev
jokerdev's Avatar
I opti coated my wheels, but still find I need to manually clean them. During washes, I'm using car wash and a microfiber wheel tool from Advance auto.
You could try using a clear coat safe wheel cleaner, let it soak, then hose off. That is what I'm planning to try next.
Old 03-10-2014, 04:31 PM
BigJoe
Support Corvetteforum!
BigJoe's Avatar
Black wheels are as hard to care for as are black cars...
I had the same dusting problem on my C6 Grand Sport. Solved it by swapping pads to Hawk ceramics. A good solution for cars that aren't tracked, at least.
(Non-Z51 cars, BTW, have almost zero brake dust.)
Old 03-10-2014, 04:43 PM
Quick Silver Z
Quick Silver Z's Avatar
Received 1,497 Likes on 1,008 Posts
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Old 03-10-2014, 05:03 PM
Motohead279
Motohead279's Avatar
Switch to Carbotech brake pads, they give off a lot less brake dust. When I had my wheels off I also used Rejex on them.
Old 03-10-2014, 05:33 PM
bluvette2000
bluvette2000's Avatar
Or...Get brake dust colored wheels. Thinking seriously about comp gray!
Old 03-10-2014, 05:46 PM
stgermain
stgermain's Avatar
I put on my c5{ A C DELCO HEAVY DUTY CERAMIC BRADE PADS }I'm going to see if they make for the c7 I don't like the dust on the black wheel
Old 03-10-2014, 05:49 PM
ATX-C7
ATX-C7's Avatar
Dust gets on silver Z51 rims also...no difference.
Put some rejex and you'll have minimal dust at best. Cheaper than changing pads.
Old 03-10-2014, 06:23 PM
Tannman
Tannman's Avatar
I don't have any more brake dust on my C7 Z51 w/black wheels than I had on my C6 ZO6 with chrome wheels.
Old 03-10-2014, 08:48 PM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Check out the 1521 compound for street use.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 03-13-2014, 10:07 AM
Supporting Vendor
Another characteristic that makes Carbotech Ceramic materials attractive is the absence of noticeable dust. All brake pads produce dust as they wear. Carbotech-Ceramic compound ingredients produce a light colored dust that is much less noticeable and less likely to stick to the wheels. On that same note, all Carbotech compounds produce a 100% non-corrosive dust that can usually be rinsed off with a hose.
Old 04-03-2014, 09:25 PM
02KillerZ
02KillerZ's Avatar
I've got to add that I've used Carbotech pads on several vehicles and just put their pads on my Raptor. AX6 on the front and 1521 on the rear. The AX6's dust is worse than my Grand Sport but holy crap do they stop the 6,000lb truck fast. Very little dust from the 1521's. But if you want the best wheel cleaner ever that is safe for painted wheels Carbotech's wheel cleaner is the best and I never knew about it until now. Just spray the wheels, leave on for a minute then hose off and they are just about spotless without scrubbing at all!
Old 04-03-2014, 09:45 PM
Snorman
Scraping the splitter.
Snorman's Avatar
Received 1,028 Likes on 486 Posts
St. Jude Donor '13-'14-'15
I had my car recently coated with Gtechniq products by my detailer including the wheels and calipers.
While it's not exactly scientific, I picked up the car last Weds, drove it probably 4-5 days and a few hundred miles and this morning, the wheels still actually looked pretty good. Before this, after a day or two of driving, I found myself washing the wheels and blow drying them. The calipers also look as if there is no brake dust on them.
S.
To Black Z51 rims and brake dust
Quick Reply: Black Z51 rims and brake dust
