AIRAID Synthamax Oil-Free Washable Air Filter C7
Why? Does it flow better while filtering better than the OEM filter?
OEM C7 disposable paper filter msrp is $99
AIRAID SynthaMax (NON-Oiled) Cleaning Instructional Video - YouTube
The SynthaMax filter media consists of an inner and outer layer of wire mesh for durable support of filtration media as well as overall filter durability. Filter construction won't deform or collapse under high air flow. Inner filter media consists of two distinct layers of specifically designed synthetic materials that have separate performance characteristics designed to work together for a combined function of outstanding air flow (low restriction) with exceptionally high filtration. Contaminants are first captured by the outer layer of synthetic needlefelt polyester material designed for wet and dry filtration with high air flow capacity. The inner layer of (wet-laid / chemical bonded) (rayon / polyester) captures any remaining contaminants while maintaining high air flow/low restriction. Each separate layer of these high tech materials are design to work together for the highest level of air flow performance & filtration with exceptional durability.
Jake - Where did you get it for $89 shipped? That sounds like a great deal!
