More expel questions...
I am getting a black car and wondering about Expel. I likely will only do the front piece, the hood, mirrors and then behind the wheels/rocker panels. I am just wondering if it is not completely applied to the whole panel, will you end up with wax lines when you wax the car. Also, even if it does cover the whole panel, can you just wax right over and it and does it look like normal waxed paint???
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,400 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
1) If you "wax" (most really aren't waxes anymore but rather a polymer of some type) over the line yes, you will see it. But the wax can be removed easily by using your fingernail with a microfiber between it and the paint. Alternately, a toothbrush works well too
2) You can "wax" the Xpel itself. In fact, they recommend it
