Leaking coolant hose at coolant reservoir.
There is a coolant leak on my 2002 Corvette C5 Coupe. I located the leak at the bottom-front of the coolant reservoir. There is a steady flow where the hose is clamped to the reservoir. I removed the hose at this point, but was unable to find the cause of the leak The hose seems fine, except for the deep imprint in the rubber hose from the spring-type hose clamp. What can I do to fix this problem?
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Closed-duplicate thread.
