Passenger Door gaps/spacing
Old 03-25-2014, 11:21 PM
ahesq
ahesq's Avatar
Default Passenger Door gaps/spacing
Check out and measure your driver's door gaps and compare to your passenger's door.
My driver's door gaps (the space/gap between the door edge and the fender) are an even 3/16 inch for both the front hinge and back latch. PERFECT!
On the other hand, my passenger door has a wide gap at the front hinge (more than a 1/4 inch), and almost no gap at all the rear edge.
I noticed this on virtually all dealer inventory and internet photos as well. From photos, it is more noticeable in lighter colors.
I am having my passenger door adjusted 1/16 inch forward to make it even all around, but in so doing, the rear striker may need to have a spacer inserted to latch properly.
Weird.
Anyone else notice this issue?
Old 03-25-2014, 11:24 PM
VETJAZZ
Support Corvetteforum!
VETJAZZ's Avatar
I had the opposite problem. Passenger door was too close to the fender and was rubbing when opening the door.
Old 03-26-2014, 12:03 AM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Mine measure 4mm (roughly 3/16 in) on my digital calipers both front and rear.
Old 03-26-2014, 11:55 PM
ahesq
ahesq's Avatar
Dealer adjusted the door today. Took all of 30 minutes.
Now it is perfect.
Hard to believe even with mass production line, most passenger doors I've seen actually were exactly like mine.
While I was waiting, I toured the dealer's lot which had about 15 C-7's on it.
Most of them needed my adjustment.
Keep in mind - This is not a cost issue, but to me it is a HUGH P.R. issue with GM's build quality.
I would never let a 100% cost free fix create such a caustic reputation on my company product's build quality.
Software issues with outside vendors in first year builds? I can understand that.
But something as simple and as stupid as this?
Hope someone at GM is listening.
Thanks for your message.
Old 03-27-2014, 02:09 AM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
The problem my car has is the driver's door bottom is inset about 3/16" from the rocker panel and an adjustment didn't fix it
Old 03-27-2014, 03:14 AM
vetteship
vetteship's Avatar
These are "acceptable" tolerances for the factory to release the car with. Sucks I know but ,.., it's no Aston
Old 03-27-2014, 06:25 AM
e6fmf
e6fmf's Avatar
Same with hood alignment. Left or Right side has 1/4 or more gap. Dealer says 3 pennies is acceptable.
Old 03-27-2014, 07:18 AM
gthal
gthal's Avatar
Received 1,170 Likes on 486 Posts
Looked at mine this morning and the gaps are are good. I found the panel gaps everywhere on my C7 to very good... I specifically paid attention to that when I picked up the car.
Old 03-27-2014, 07:28 AM
kp
kp's Avatar
My pass door is like that, If I tried to adjust it out, or the fender in, it will rub higher up. Its very close to rubbing in the middle right now when opening. The contour of the fender doesnt exactly match the door.
Old 03-27-2014, 07:53 AM
CRABBYJ
CRABBYJ's Avatar
Received 1,293 Likes on 722 Posts
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
The same is true with my C7. All gaps appear perfect. And I was very critical of this before I purchased mine from stock at a Dealer.
My '05 C6, a very early build (#117X), had a similar gap problem with the driver's door. The front seem gap was slightly wider than the rear seem The driver's side rear seem measured the same as both passenger door seem gaps. I saw the same issue on many other early build '05 C6s.
At the April, 2005 C5-C6 Bash in BG I brought this issue up with plant personnel and they measured my gaps. The said they were in tolerance but if I was unhappy my dealer could adjust the gap either moving the driver's door or driver's side front fender. I never bothered.
Old 03-27-2014, 11:11 AM
travisnd
travisnd's Avatar
The inset at the bottom of the door is by design. It's been discussed in other threads. Apparently it helps with wind noise and air intrusion.
Old 03-27-2014, 11:23 AM
KenHorse
KenHorse's Avatar
Funny....took my car to my local dealer to have a look and they didn't have a clue
Thanks for the heads up.
Here's the thread
Old 03-27-2014, 11:28 AM
travisnd
travisnd's Avatar
Here's the thread
Old 03-27-2014, 11:32 AM
bluestreak63
bluestreak63's Avatar
But like ahesq reported some tolerances can be adjusted by your dealer....
If they took the time to get all the gaps right at the factory, some wouldn't receive their C7's for over a year. Think of the outcry on that one...
Old 03-27-2014, 11:42 AM
BigJoe
BigJoe's Avatar
Catches all kind of dirt and grit on the little "shelf" under the doors. Both sides. Apparently by design (see post 11) but regardless it is a PITA to keep clean.
Old 03-27-2014, 12:46 PM
Diesel88
Diesel88's Avatar
I will have to friendly disagree with that part. Only because in the Motor Trend special edition Corvette stingray magazine GM says different. In the assembly/plant tour section they have a picture of a plant worker using something to check the door gaps. In caption it says, "Panels are carefully gapped, so a $52,000 Corvette looks far more expensive". You should not point out how much detail goes into the door gap and have this many issues. There are other sections they point out in the magazine that are very interesting to read. Guess they only inspect every few cars with that special eye.
Old 03-27-2014, 04:43 PM
kp
kp's Avatar
Then why is my is my drivers door lined up fine? If you are talking by the sill plate/rocker being inset thats true, I'm talking about the large body line a few inches up from the bottom edge. The drivers side lines up with the fender and the pass side isnt even close.
To Passenger Door gaps/spacing
Old 03-28-2014, 10:16 AM
travisnd
travisnd's Avatar
10-4... I'm talking about the rocker panel vs. bottom edge of the door.
Old 03-28-2014, 10:38 AM
kp
kp's Avatar
No problem, just by looking you can see the bottom edge of the door is supposed to be like that, no way you could move it out enough to take that out
This is what I'm talking about, my guess is is its a compromise, if I did move the botton of the door out a little I bet it would catch when opening somewhere. The fender cant really be moved in any more, its as far as it can go. I'm not going to fool with it, no wind noise, door closes well and I dont see that side often.
Not really a big deal, except the drivers side lines up almost perfect. Just something I noticed after washing it the first time..
Old 03-28-2014, 10:43 AM
travisnd
travisnd's Avatar
You should be able to fix that... if the hinges on the C7 are similar to the C5/C6. It can be tricky to get it right by yourself. Having a 2nd set of hands is a big help. You can loosed the four bolts that go into the door shell and rotate the door a bit. I'm not sure of the attachment points on the fender of the C7 but it sounds like you know your stuff. On the C5 there's one attachment bolt in the center back of the fender that you have to get at from the wheel well with a long extension. This controls how much the fender "bows out".
Quick Reply: Passenger Door gaps/spacing
