** New C7 Front License Plate Brackets Available from Top Flight Reproductions **
#41
Hi Bob, under Corvette plate products here: http://www.topflightrepro.com/corvet...brackets.shtml
#45
Navigator
Hi Bob, the Frames are located here: http://www.topflightrepro.com/corvet...e-frames.shtml
Do you make the frames in the C7 DSOM color? I don't see it in your link.
#49
What I would really like is a grill mount that has a way to be taken on and off the car without removing the license plate. Right now the only way to do that is to drill holes in the license plate, which I would prefer not to do. Any ideas?
#52
C7 Corvette Front License Plate Brackets
If you live in a state that requires a front license plate, we have two great solutions for your C7 Corvette. Both of the Top Flight Reproductions front license plate brackets allow more air flow than the standard GM grill mount and attach with just two fasteners. There is no drilling or modifications required to your corvette.
** Features of the "Low Profile Mount" include less blockage of air flow, a sturdy aluminum construction with a black powder coat finish that attaches using existing screws. **
** Features of the "Grill Mount" include a Slim-Line look, an increase in air flow through the grill compared to the GM mount as well as ease of installation. **
NOTE: The GM C7 and C6 Body Colored License Plate Frames (sold separately) can be used with all of the Top Flight Front License Plate Brackets to enhance the look of the front plate.
ORDER HERE: http://www.topflightrepro.com/corvet...brackets.shtml
C7 Front License Plate Bracket "Low Profile Mount"
Shown with optional GM colored frame
Mounts to the bottom of the lower front bumper using two existing screws
C7 Front license plate bracket "Grill Mount"
Return the GM Front License plate bracket P/N 22830069
back to us and we will issue you core refund
(the P/N is located on the back side of the part).
Mounts using the Fastener Kit shown below
Grill Mount Fasteners qty of 2 per kit
** Please note that these are not supplied with the above
"Grill Mount" Front license Plate Bracket. If you have the GM
Grill mount you can use the same two fasteners. If you do not
have the GM Grill mount you will need to order this fastener kit. **
#59
Have you mounted the low profile version on a Z06 with stage 3 aero?
