Need Help: C7 fuel door will not unlock
1. Yes, the lock plunger is retracted when it is UNLOCKED
2. …and the plunger is extended when LOCKED
The plunger moves with very little pressure applied when in the extended locked position. Very easy to push the door closed if it locks while the door is open. If yours is hard to move then something is definitely binding somewhere.
It's just a simple solenoid plunger, your dealer should be able to handle this easily as it will be a remove and replace operation. From what I've experienced this whole car is assembled with push clips and fasteners! Everything seems to just pop off once you figure out where to pry...
Good Luck!
Good Luck!
You even anticipated my third question, which was how much resistance did you feel pushing in the solenoid. Mine is definitely messed up, it required a lot of pressure to push it in, enough that it's painful to try and keep it held in.
Thanks for the help!
I did not try to pull the fuse. I will test tomorrow, but I really doubt it will do anything because I'm sure the lock solenoid is designed to be extended when power is off (extended by a spring) and then it contracts when energized (unlocking). So without power, it will just stay failed in the extended position (locked).
I won't post the video because my daughter managed to insert herself mid-stream and the audio is horrible (gas station in the middle of downtown philly). But maybe I'll do another video tomorrow. I'm going to give it some WD-40 tomorrow to see if it will free up.
Last edited by Steve Garrett; 04-23-2017 at 12:43 AM. Reason: Merged Posts-please use the Multi-Quote button (the middle icon) in the lower right hand corner of each post to make your responses look like this!
ok, weve now documented that problem. lets see if, one by one, we can compile a real owners manual--be what, 5,000 pages? we ll call it "when science fails". btw, OP, great job with sharing your experience. well documented, well thought through. about 10 minutes into it, id take the small sledge hammer i carry in the trunk and bash the sh*t out of the cap. then id go to my local dealer and ask what hed give me for it--you know, before the carfax got entered, and it became unsaleable at any price (or so we re told).
Now another ~two week wait for the replacement part...
Here is a picture of the actuator that failed (it's the white box). This view is from the driver's side rear wheel, with the fender liner pulled back, looking forwards towards the fuel fill line.
Johnp94 (05-13-2017)
What a great service you have provided to us all by posting your issue and solution.
I hope to pick up my C 7 in two weeks and my question may be covered in the owners manual that I do not have so, be kind in your replies..
Question, can you configure the car so that the electronic gas door lock never activates? Obviously this means that you have to rely on the manual latch to keep the door closed... Just like my Cadillac!!!
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
So......
Removing the metal rod locking device will free the door to open by pushing on the rear of the door whether or not the doors are locked or unlocked. Seems to me that would be how we have on the C6 and older. Open unlocked door, fill tank?
I think what I'm saying is if this problem strikes, removing that locking device will fix the problem never to repeat again?
Elmer
Elmer
There is no identified option to do this electronically.
The lock is controllable from the technician's workbench computer that plugs into the car for diagnostics, so of course in theory there could be a way to do it.
But I suspect the actuator is 'energize' to unlock and locks when deenergized. So you'd have a constant drain on the battery if you wanted to keep it open. Not great.
There are mechanical ways to achieve the same outcome
You could of course just take a hacksaw and cut the bolt of the electronic lock out, hat'd be pretty easy, but not reversible. [Please be careful not to create a spark!]
A less 'permanent' solution would be to plug the bolt hole that the electronic lock bolt slides into. Lots of clever ways to do that while still being reversible.
As you suggest, the hatch would still work fine. A few folks have reported problems with the fuel door popping open, but this is generally attributable to the situation where:
1) They close the door where the electronic bolt has already extended (I think it times out after 1-2 minutes after the unlock)
2) The door gets pushed in far enough to hang up on the electric bolt, but not catch on the manual door spring latch.
3) So when they unlock the car again, the door opens as the electric lock release.
So......
Elmer
Elmer
Especially because that white lock mechanism isn't parted separately, they have to order a whole new hatch.
Thanks for the info and detailed pictures. This is good info to know if it strikes (always at an inopportune time!)
Sorry you had to learn how it works and how to get the cover open by being locked out of the gas filler!
Ed
Ed
Thanks for posting this. My fuel door wouldn't open this morning in 36 degree weather. Drove it home and got out of the car and then it was open.
1st Gear
You're not alone.
My 2014 C7 was low on fuel. At the gas station I could hear the gas cap mechanism click, but it would not open. All permutations of key/door/voodoo failed to open the thirsty tank. To make a long frustrating story short, I was 3 miles from the Chevy dealer, who can have a part in 3 days. I tried all of the forum suggestions, and even tried to pry off the cap. I couldn't make myself pull hard enough for fear of cracking my baby. Future fears of being stuck miles from home at night make me desire a fix of this issue, or at least a way of over-riding the cap so I/we can get safely home. Does anyone know of an over-ride, factory or aftermarket?
^^^ Have not seen any manual override kits, but I recently had to remove the left rear wheel well to replace the fuel filler inlet pipe, and I almost went ahead and removed the lock mechanism while I had it apart...
After seeing this post again, I may go back and remove it... These days I actually would be more worried about someone pouring something INTO the fuel tank, and not about having gas stolen...
If desperate, and you do not want to rip off the door, you could carry the torx head socket (torx #15) to fit the wheel well screws, so that you could remove them and get your hand into the fender to manually pull the lock bolt back..The liner is stiff, but I would rather even cut a hole in the fiber liner than risk breaking the gas door.
With a little thought, someone (maybe me) could also figure out a way to hook a manual release cable to the mechanism for an emergency.. even a secret strand of fishing line run from the lock to the edge of the wheel well could save you a lot of grief.
#33
My C7 is currently stuck at a gas station, the fuel filler door will not open [UPDATE: I pried off the gas door, over-rode the electric lock, which had failed in the locked position, and refueled the car. Pictures of the process in a later post on this thread.] . I've successfully refueled the car previously, this is the first time the lock has failed to unlock.
I know where to push to get the door to open.
I have verified the car is unlocked. Putting my ear on the fuel door while pushing the unlock button on the drivers door, I can hear what sounds like a solenoid trying to unlock the fuel door. It clicks once for each time I unlock the door.
I'm out of fuel, so my only safe alternative sounds like I'll need to tow it to a dealer for warranty work on the lock.
Anyone have a picture of the locking mechanism, I'm half desparate to jam a big screwdriver in there and pry the thing open, so I can drive the car.
I'll take any suggestions.
#34
Elmer
#35
^^^ If you tie them to the same handle, then the distance you have to pull the handle to release both latches would have to be the same...otherwise one would release and the other may still be latched. You could always tie both to the handle but leave slack in the fuel door release and pull it separately.
#38
Received 1,986 Likes
The ? really is why did they design a "locking gas door" at all??? Not much of a detriment to anyone want to dump something in your tank. And you cannot syphin gas out of modern fuel tanks anyway. I have a capless fill on my ford and it does not need to lock so that is not the reason.
GM remove the lock. This is a problem waiting to happen...........now for some long term for the rest.
#40
Not that hard to get to, but does require removing the wheel well liner...
