Spare tire ?
Old 04-21-2014, 01:31 PM
hankman
hankman's Avatar
Default Spare tire ?
Does the C-7 come with a spare tire?
Old 04-21-2014, 01:34 PM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
No, neither did the C5 or the C6. Run flats.
Old 04-21-2014, 01:36 PM
arcticblast
arcticblast's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
The one around my waist is not considered original equipment.
fsvoboda
fsvoboda's Avatar
Only some drivers.
Old 04-21-2014, 01:37 PM
fsvoboda
fsvoboda's Avatar
Like mine, probably rated for low speed use only.
Old 04-21-2014, 01:42 PM
Scoobydoobydoo
Scoobydoobydoo's Avatar
And over inflated.
Old 04-21-2014, 04:56 PM
GTFD2
GTFD2's Avatar
Never could understand the need for a spare tire in modern cars. Do any cars come with any other spare parts like a starter or alternator.
Old 04-21-2014, 05:45 PM
wgood
wgood's Avatar
Well how about an air compressor ??? I have a 2005 Bonneville GXP daily driver that has a compressor built in and located in the trunk !!! My old 1990 bonneville SSE also had one !!! Or get a portable one or have AAA do it if you get stuck ! Plus you have roadside assistance 24-7 !!! Ye Ha !!! Wayne
HolyRoller
HolyRoller's Avatar
Does the C7 come with a spare tire?
No! Spares are for sissies! So are run-flats! It takes a real man to whip out some Green Slime.
There's just no room in a C7 for a spare, and it would be heavy. My 2006 S2000 had a compact spare in a neat little compartment to one side of the convertible top space. When I traded it for the S2000 CR (Club Racer) version, they just omitted the spare, leaving that compartment empty, and put a tire repair kit at the bottom of the trunk, saving probably 20 pounds. It also had a rear wing, leading some to say that CR really stood for Club Ricer.
A lot of people think this is all you need instead of run-flats, and they could be right, since any tire gash too big for fix-a-flat to plug would probably make a run-flat unsafe to drive. Personally I'll stick with run-flats on my C6, since they've come in very handy a few times.
Old 04-21-2014, 05:46 PM
thedofuss
thedofuss's Avatar
ive had about 7-8 flat tires in my life--never i a convenient time or location. ive had zero starters or alternators blow.
Old 04-21-2014, 05:50 PM
wgood
wgood's Avatar
You are right and if stay away from new construction and roofing jobs you could probably cut that in half !!! Wayne
To Spare tire ?
Quick Reply: Spare tire ?
