Install Catch Can in C7 Info?
#41
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Catch cans work if you’re willing to check and clean periodically (every ~1000 miles etc.). Most car owners would not want to, care to or want to know how! It’s just that extra help some of us care to install.
#42
It's more critical on boosted cars but an extra safeguard on all cars.
#43
Same issues exist with Ferrari, Porsche, BMW and others with Direct Injection (other cars as well but not as critical since gasoline with port injection helps clean the coking caused by blow-by coming from PCV system etc, creates.) In Europe many oil companies do sell truly “full synthetic” oil which is a help. In the US with the recent lawsuit, which Mobil lost, the marketing words “full synthetic” fits some blends as well-who knows what Mobil 1 is currently!
#44
I can't speak to that yet, as I am just in the process of getting and installing. My understanding is it would require more frequent maintenance than say an oil change. It will depend on the way you drive as well.
#45
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I'll be checking mine tomorrow - I have around 300 miles on the catch can
#47
I'll check mine tomorrow as well.
#48
Did you disconnect the battery before removing the ground cable tie-down bolt for mounting the can support bracket?
How did you go about removing the covers to gain access to the connection ports?
#50
The fuel rail covers pop right off. Once they're off, you can remove 4 10 mm bolts that hold down the plenum cover. There's no need to actually remove it as all you need do is lift it out of the way to get to the nipples you need
#51
Ken- if you can, check the upper part of the canister. I think there is a stainless steel mesh that is in a smaller canister that can be unscrewed to clean the mesh. Seems to me the mesh would have to be cleaned periodically for maximum effectiveness.
I didn't remove the mesh because I think the can has to be unmounted to get at it.
#52
Didn't disconnect the battery, nope (no sparking noted either)
Just to be on the safe side, plan to remove anodizing on catch can support bracket in areas that contact lower mounting surface and mounting bolt flange; that ground cable size looks like it sinks a fair amount of current.
#54
Last question for sure; did you order your CC with the single check valve feature ? If so, did you not use the OEM check valve in the U Tube Assembly?
As for the mounting/grounding, a star washer will take care of that...
#55
My Elite is coming with just an inlet and outlet as you used with the lines going to and from the can replacing the short OEM line. Looking at the Rx install with two outlets, it looks like for the 2nd outlet you would use a check valve. The reservoir cap I also ordered goes from the cap to baffles in the front of the air box replacing the OEM line, so also assume no benefit of a check valve there.
#56
#57
Was unaware of any issues with the C7 PCV valve. Will have to consider.
#58
If you install the Elite catch can without the OEM hose and check valve (which is no longer used) is this a bad thing? What does the check valve really do? Can you simply buy Elite's version and use that?
I was about to install my can and now I'm waiting until someone who knows more than me can clarify.
#59
OK... some educate me on this
#60
What I meant to say was whether the check valve is needed on the C7. Elite Engineering doesn't seem to make a big deal of it relative to their catch cans so I'm more wondering whether it is a big deal on this car. I'm going to connect with them and get their thoughts.
Also, last night I checked my intake for any signs of oil and it was bone dry and completely clean. 1,500 miles on the car.
I still plan to use the catch can once I can clarify the check valve issue.
