How do allocations work in relation to part/package constraints?
If a dealer has an allocation for, let's say, a Z51 coupe, and they place the order (status 1100), then it gets accepted (2000), then queued for production/accepted by production control (3000), does that mean that regardless of the constraint, the ordered car is accounted for and can be produced?
Do the 'constraints' simply limit the allocations that GM gives out, or does it end up limiting the orders placed by the dealers with allocations?
It seems like the former would be more accurate, otherwise why would GM allocate a car to a dealer that they cannot actually build due to a constraint.
Sorry if that's confusing.
More simplified: are constraints taken into consideration when the allocation is giving to the dealer?
This is correct. I have personal experience (as many do). My dealer in late 2013 had 3 coupe allocations; I was number 3 of 3. When my allocation was available in October 2013 Z51 was on constraint. I had to choose between taking the allocation WITHOUT Z51 or waiting for a future allocation to come available and hoping I could get Z51 then. I chose the latter option and in December my car was built and delivered. I DID write several letters to Customer Service (that they DID respond to) and my dealer pressed his regional rep pretty hard - I DO think those actions caused my car to "appear" almost magically (because my dealer did NOT have an available allocation at the time). I waited 6 months - long forgotten now that I have the car.
If GM picks up the order and it goes to 2000 then barring a major quality issue like they discovered with the CF roof the order has passed constraints and will get built. Constraints mean nothing once the order is at 2000 or higher.
You can't go past 1100 if an item you want is on constraint and your dealer doesn't have an allocation for that constraint. The dealers allocation report will show how many of each constrained item they can order.
It makes more sense this way.
Ok, have a question... If your #1 on a dealer 2015 allocation and your car is heavy with possable constrants does the order get skiped or just sit there until they have parts for your car/ order number. sorry confused by what i was told before..
Your order will get skipped unless you agree with the dealer to remove those constrained items. If you really want those items, wait.
Bottom line, if you are at 2000 you have passed the constraint hurdle.
No it won't unless you change the order and add a constrained item OR something changes between the time GM accepted the order and the move to 3000. This "something" would,have to be major like a bad batch of parts, a blizzard or a suppliers truck crashing with specific parts needed for your build being destroyed. Even then, all it would do is delay the move to 3000 status. New items added to constraint on the weekly consensus DO NOT effect orders at 2000 status, only orders at 1100 status waiting to be picked up by GM.
Thanks for the responce...clear as mud GM makes it..
3000 means the assembly plant has accepted the order.
2000 means GM and 2500 means Chevrolet have accepted the order.
Is there a chance a 2000 will not be built in the model year it was made? Is there a chance a sink hole will open in the middle of the Bowling Green Assembly Plant?
Laborsmith
These codes are intended for GM internal use and work well for that purpose. They were not in the past and even now in the present intended for a public use. Could there be modifications so we not inside GM can understand it all? Yes but I am not holding my breath.
Laborsmith
Laborsmith
