Seats too narrow for me - how about you?
...I actually measured the width of the seat bottom of my C7 verses my Z06 and found that the C7 was about 1/2 inch wider than the Z. Then I noticed that the height of the seat bolsters on the C7 were taller and obviously firmer than my C5. I can only assume the design is to keep my *** in the center of the seat cushion...
Subjectively, I think you have the reasoning right.
I also think the design forces you into a better driving position.
two biggest things I've noticed:
1. Can't have poor posture (scoot forward or try to sit off center, feels like there is a slightly elevated "divider" in the middle of the seat).
2. No "detroit lean" towards the console (or you can't see part of the HUD)
Compared to my C5, the C7 GT seats hold me in place much better, making it easier to drive harder, so to speak, without feeling like I am sliding side to side in the seat.
The C7 is my first corvette and I LOVE it! So this is just a small issue but wondering if it's just me.
I'm 6' 2" tall and 200 lbs. and I find the seat bolsters too narrow (NOT the seat backs - the seat bottoms - I know the seat back bolsters are adjustable and they're great. I'm talking about the part you SIT on).
I have longish legs so when I sit, my legs are slightly bent up and slightly splayed out left and right. It feels like the left and right seat bolsters are digging into the bottom of my legs after a while.
The back bolster adjustment doesn't seem to affect the seats - only the back left/right bolsters wider/narrower. It doesn't make the bottom part of the seat bolsters more wide open (flatter).
Anyone else feel this?
Thanks,
Raym
Thanks,
Raym
Me too. I'm 6'1" 195 pounds. I went from a 2014 GT 500 with recaro seats which fit me perfectly. Honestly this is the only thing I feel needs improving on the Stingray. My thighs sit on top of the bolsters while in the Shelby I fit snugly between them. The bottom seats in the vette are just a little too narrow. Btw the vette is a 2LT with gt seats.
VAVetteC7 (11-23-2016)
Thanks,
Raym
Thanks,
Raym
I'm 6'3", 200 and have 3LT standard seats. The bolsters hit me in the back of both thighs. The passenger side seems much worse. The outer bolsters seem worse than the center bolsters.
I'm not done with playing around with the seat angle but I think these seats are not designed for just relaxing in them. The bolster needs to be softer or moved to the outside and the angle needs to be adjusted. Maybe the foam is a little too stiff. I suppose if you drive with your knees together, they would be ok. I'm thinking that the thread on the edge of the bolsters will start wearing quite soon.
Seat backs and the seat overall is quite an improvement over the early C6 seats but they may have gone a little too far.
I'm 5'11" at 185 and I tried all the seats at Barrett Jackson last Jan and didn't like any of them. They look great until you sit in them for a while.
Seat bottom bolsters are hard and too close together in my opinion.
My brother's 2012 E63 AMG and has a similar problem.
Wish they were as comfortable as the 20 way adjust sport seats in my 535 Bimmer.
One of the main reasons I'm keeping my C6.
Guess my *** doesn't like most sport seats.
Thanks,
Raym
Thanks,
Raym
I have the exact same complaint as others - the bottom bolsters are too hard and a bit too close together or to high relative to the seat bottom. 3LT standard seats. I can deal with it, but it's not really comfortable (yet) after 3500 miles.
Do you mean tilt the seat bottom so it's more level? Have to give that a try...
I had a similar problem with my 2005 Honda. The seat cushion side bolsters were rock hard and my thighs pressed into them. What made the seat tolerable was shaving off a little of the top layer of foam on each bolster and drilling holes in the foam to make it softer. This preserves the contour of the foam and the size and placement of the holes can reduce the density where you need it. It took a few tries to get it right, but I still have the car and the foam has softened even more. I couldn't stand it before the holes were drilled.
#33
#35
The seats I'm complaining about are the GT Bucket seats and the car is a stick.
Thanks for the replies. Sounds like a decent portion of you folks are having the same feeling of the bottom bolsters pressing hard into your thighs underneath like me. Since even some of you larger folks don't seem to mind it, some of us may just be more sensitive to that pressure than others.
The back bolsters don't bother me at all - I have them as wide as they'll go. But that doesn't help the bottom bolsters.
I've put 5,000 miles on it since getting it in February and it's my daily driver. Hopefully those lower bolsters will loosen up a bit over time but for now, sounds like I'll just have to live with it. I was hoping I was missing some adjustment somewhere but it sounds like that's not the case.
Thanks!
Thanks!
#36
Last year at this time there was no way I would have considered the Comp seats, but since then I lost 140lbs, yep 140lbs. I am 6 foot 1 inch, now weight 182lbs and the seats are PERFECT. We also own a BMW 335i with stock buckets seats, and the comp seats are so much better for lateral and back support....We love the comp seats so much better than the stock seats....no problem here.
#37
Yep. One of the first things I noticed when driving the car. I'm 6'3" and 208.
Thanks,
Raym
Thanks,
Raym
#38
I'm 6'0" and 225 lbs. Left bolster in bottom of the seat digs into the back side of my thigh. Find the seat uncomfortable because of that. Back of seat is fine. Standard seats in my M7 Z51. By comparison the seats in my GT-R fit just fine, no pain in the back of the thigh, and it is made in Japan, where people are much smaller on average. Plus it holds me just fine on the race track, no sliding around.
Wish there was an option for a different seat bottom in my Stingray.
#39
I'm hoping seat/cushion companies come out with an after-market product that would help - a seat cover that smooths that bottom out a bit or a pillow shaped to exactly fit in that space to make the distance between the seat bottom and the bottom bolsters less aggressive.
I've tried a lamb skin cover that helps a little but then it looses all the leather seat feel that I love in the first place.
Thanks all - I was starting to think it was just me,
Raym
Raym
#40
For those that just cant "adjust" either seat style to your liking, I'd suggest contacting John Carivaggio (not sure of the spelling). His "upholstery talents" are magnificent. I have not seen any C7 seats he has done but, his C6 seats can be seen in the C6 section. I'm sure if anyone could "customize" your seat bottoms to fit you better, he is the man. JMHO
