C7 Corvette Custom LED Lighting Kits Now Available from NAT - Interior/Exterior
Former Vendor
Hey guys,
We've put together quite a list of our most popular LED kits for your 2014-2015 C7 Corvette Stingray...we always include free shipping with these kits and our prices cannot be beat
C7 Corvette Stingray LED Footwell Lighting Here: http://www.northamericantuning.com/product_p/bfwc-7.htm
Introducing our new LED footwell lighting kit for the new C7 Corvette Stingray. This kit will light up the entire footwell area not just a small area like the factory light. This C7 Corvette Kit includes led strips with 15 BRIGHT leds per side. Covers drivers and passenger footwell and retains the "theater" effect of the factory interior lights. With all our available colors other corvette owners will be checking your car out! Installation takes 1/2 hour and instructions are provided.
C7 Corvette Stingray Hood + Cove LED Lighting Kits Here: http://www.northamericantuning.com/p...s-7-sb-2rm.htm
Introducing our new C7 fender cove and hood vent led lighting kit. This kit is designed specifically for the C7. Kit comes complete with only 2 easy connections to make under the hood. This remote control switches the leds on or off only. Please check out our 4 function remote control kit also.
The kit includes the following:
*(2) 18" waterproof led strips w/27 leds on each side for the fender cove.
*(1) 28" waterproof led strip w/42 leds for the hood vent.
*Complete wiring harness.
*Our kit has extra leads on the fender cove wiring so you can wire our rear facia kits to work with the remote instead of coming on with the lights. *Installation hardware.
C7 Corvette Stingray Rear Fascia LED Lighting Kit Here:
http://www.northamericantuning.com/p.../c7-rfsb-5.htm
Introducing our new C7 Corvette rear fascia led lighting kit designed specifically for the C7 Corvette Stingray. This kit is pre-wired to tap into the rear side markers so they will come on when the marker or headlights are on. They can also be wired into our C7 Corvette fender cove and hood scoop kit if you want to control them wirelessly. Purchase our under car wiring kit if you want to wire them to the cove lighting kit. This is a great option for car shows or cruise in's. This kit will illuminate the vents on each side of the taillights and the vents on the lower rear fascia and also includes a exhaust area lighting kit. Select from our many colors but RED or Yellow/Amber may be the only legal colors. Check the laws in your state. If you want to use other colors we recommend using our fender cove remote controlled kits to run this kit so you can turn them on or off when wanted.
This kit includes:
(2) waterproof led strips per side with a total of 54 superbright leds.
(1) exhaust led kit with 24 bright waterproof leds.
Mounting hardware.
Instructions
C7 Corvette Stingray Exhaust Area LED Kit Here: http://www.northamericantuning.com/p...c7-exh-1-b.htm
Introducing our new C7 Corvette Stingray Exhaust Led lighting kit. Choose between our BRIGHT or SUPERBRIGHT kits. Kit comes with a 16" waterproof LED strip with 24 leds and wiring to tap into the rear side marker lights so it will come on with the lights. Installation take about 1 hr.
C7 Corvette Stingray Grille Area LED Lighting Kit Here: http://www.northamericantuning.com/p...c7-gr-42-b.htm
This is an optional kit that can be added to work with our C7 Corvette Stingray LED fender cove/hood vent kit. It lights up the grill opening and is very easy to install with our fender cove/hood vent led kit. It comes with a self adhesive waterproof led strip with 42 leds and connects to our wireless remote controlled lighting kit so you can control it with the click of a button. You can select from 2 brightness levels. Bright for a nice glow or Superbright for those who want the most light available. Installation takes about an hour.
C7 Corvette Stingray LED / LOGO Door Sill Plates Here: http://www.northamericantuning.com/product_p/051017.htm
Customize your Corvette Stingray with our LED illuminated door sill overlays made from brushed stainless steel or polished stainless steel. These overlays fit over your factory door sills to give your Corvette a clean custom look that's uniquely your own. Get a leg up at the car shows by ordering today.
NOTE: a hole needs to be drilled into the vehicle on each side of car under this sill plate to route 12 volt wire to power the led lights.
Description
100% Stainless Steel.
Brushed finish.
Will not tarnish, fade or rust.
Laser cut, for a precise fit.
Adds a unique look and style to your car.
Fits all 2014+ Coupe and Convertible Corvette Stingrays.
Sold as a (2) piece set.
NOTE: Please select your LED color when ordering.
Made in USA!
This kit includes:
Mounting hardware.
Instructions
Description
Brushed finish.
Made in USA!
Former Vendor
Hey guys,
This kit includes:
Mounting hardware.
Instructions
Description
Brushed finish.
Made in USA!
This kit includes:
Mounting hardware.
Instructions
Description
Brushed finish.
Made in USA!
Former Vendor
Former Vendor
Ease of Installation of LED Lighting Effect systems
I would like to hear from folks that actually installed these LED lighting systems and get their experience on how hard was it, is it really a DYI project, can multiple systems (e.g. Hood, Cove, Rear, etc.) be controlled from one remote, etc.
Also interesting on which brand and where did you get the best price and support?
I really want to do this with my new 2016 Z51 NRB. I'm taking delivery next week at Kerbeck! Can't wait, hope the weather stays like it is now in the NE, warm and sunny!... I leave in Pittsburgh and plan to drive it back from Atlantic City next Friday...
Look forward to seeing posts with pics on this topic...
Former Vendor
Hey guys,
This kit includes:
Mounting hardware.
Instructions
Description
Brushed finish.
Made in USA!
This kit includes:
Mounting hardware.
Instructions
Description
Brushed finish.
Made in USA!
