Check this out!! C7 Corvette APR Real Carbon Fiber Parts available @ RPI Designs !!!!
Platinum Supporting Vendor
C7 Corvette Stingray Base and C7 Z06
APR Real Carbon Fiber Front Air Dam Splitter
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR front air dam splitter.
Made right here in the USA, this front air dam splitter utilizes a built-in aerodynamic design that creates a high-pressure region of air above the protruding surface, which helps reduce lift and increase high-speed cornering.
Of course, if you are not into racing, this piece also provides a great visual upgrade over the factory look.
Get your order in today.
Item #
FA-207007
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=4935
C7 Corvette Stingray APR Real Carbon Fiber Rear Deck Spoiler
This APR rear deck spoiler is made right here in the USA, is not only a beautiful piece but is also designed to be functional, reduces rear-end lift and drag.
This piece works great on its own or coupled with our front air dam splitter.
Item #
AS-105707
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=4934
C7 Corvette Stingray Z06 style Carbon Fiber Rear Spoiler
C7 Corvette Stingray and Stingray Z51 real carbon fiber rear spoiler with an adjustable panel.
This rear spoiler is much like the factory Z06 spoiler that comes on the C7 Z06 from the factory.
If your C7 Corvette came with a spoiler from the factory then this spoiler will mount in existing holes.
If your Stingray did not come with a full-length spoiler you will need to drill new holes.
This rear spoiler is made out of real carbon fiber and features a high clear coat finish.
Factory-like fitment
This vehicle-specific component is designed to match the contours of the vehicle's rear deck area, for a factory-like fitment.
Carbon Fiber Construction
This component is formed in the autoclave at high temperatures using pre-pregnated carbon fiber manufacturing processes, for high strength and low weight.
UV Resistant Coating
Each Rear Deck Spoiler is finished with UV-resistant clear-coat paint for resistance against various environmental conditions
Item #
AS-105727
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=5138
C7 Corvette Stingray Carbon Fiber Rear Heat Shield by APR
For the C7 Corvette Stingray owner that has added a carbon fiber rear diffuser.
Our real carbon fiber rear heat shield is a complete replacement part made 100% of carbon fiber.
Simply remove your existing panel and install this right in its place.
These rear heat shields are made by APR performance and will work with OEM stock rear lower valance panel or the APR carbon fiber lower valance panel.
Item #
CBX-VETTSSHIELD
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=5137
C7 Corvette Stingray and C7 Z06 Real Carbon Fiber Lower Diffuser
This C7 Corvette Stingray real Carbon Fiber Rear Diffuser is a direct replacement of your existing diffuser.
Made in the USA by APR.
*Rear diffusers help reduce turbulence of the under-body airflow that exits the rear of the vehicle. This helps to reduce both lift and drag
Item #
AB-277019
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=4971
C7 Corvette Stingray APR Real Carbon Fiber Side Rocker Extensions Skirts
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR C7 Corvette Stingray side rocker extensions kit.
Made right here in the USA, this side rocker kit helps reduce under-body turbulence, lift and drag by limiting excess airflow to the underbody.
Of course, if you are not into racing, this kit also provides a great visual upgrade over the factory look.
Item #
FS-207008
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=4936
C7 Corvette Real Carbon Fiber Front Fender Vents
This C7 Corvette carbon fiber side front fender vent set is a direct replacement of the OEM GM plastic pieces on the right and left front fender.
Simply remove your existing vents and install this real carbon fiber vents.
Item #
CF-700002
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=4932
C7 Corvette Real Carbon Fiber Hood Vent Insert
This C7 Corvette carbon fiber hood vent is a direct replacement of the OEM GM plastic piece. Simply remove your existing vent and install this real carbon fiber vent.
Item #
CF-700005
Website Link :
http://www.rpidesigns.com/shop/item.aspx?itemid=4931
C7 Corvette Real Carbon Fiber Rear Quarter Panel Vents
This C7 Corvette carbon fiber rear quarter panel vent set is a direct replacement of the OEM GM plastic pieces on the right and left rear quarter panels.
Item #:
CF-700804
Website Link:
https://www.rpidesigns.com/shop/item.aspx?itemid=5450
C7 Corvette Stingray Base and C7 Z06 Real Carbon Fiber Side View Mirror Housings- set
These C7 Corvette Stingray Carbon Fiber Mirror Housings are very lightweight and replace your existing mirror housings.
This mirror conversion kit replaces the factory mirror housings (but reuses the existing lenses and power mirror mechanisms).
Item #
CF-207007
Website Link:
http://www.rpidesigns.com/shop/item.aspx?itemid=4970
You Can find all our APR Performance parts available for purchase HERE.
If you have any questions don't hesitate to ask!
Our customer service team is available through email:
rpi.designs.customerservice@gmail.com
or
Call Toll-Free:
888.257.8515
You can contact our sales team at this email address
paulrpidesigns@gmail.com
If you would like to visit our Online Catalog and view all of the C7 Corvette Parts
and Merchandise that we have available for sale,
just click this link
C7 Corvette Accessories| C7 Corvette Parts
Thank You!
__________________
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Wow, RPI Designs-stepping it up-everything looks terrific!
Did anyone notice those side mirrors?????
RPI's looks great. I hope you will be doing the same for the Z06 as I ordered a Base Z06. As it is an A8 I don't really expect it till Spring, but will interested in talking with RIP.
Yes, it does. Same 2x2 twill.
You bet! We'll have those before too long as well.
C7 Corvette Stingray Base and C7 Z06 APR Real Carbon Fiber Front Air Dam Splitter
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR front air dam splitter. Made right here in the USA, this front air dam splitter utilizes a built in aerodynamic design that creates a high pressure region of air above the protruding surface, which helps reduce lift and increase high-speed cornering. Or course, if you are not into racing, this piece also provides a great visual upgrade over the factory look.
Item # FA-207007 $997.95 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4935
This APR rear deck spoiler is made right here in the USA, is not only a beautiful piece, but is also designed to be functional, reduces rear-end lift and drag. This piece works great on its own, or coupled with our front air dam splitter.
Item # AS-105707 price $755.25 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4934
C7 Corvette Stingray and Stingray Z51 real carbon fiber rear spoiler with adjustable panel. This rear spoiler is much like the factory Z06 spoiler that comes on the C7 Z06 from the factory. If your C7 Corvette came with a spoiler from the factory then this spoiler will mount in existing holes. If your Stingray did not come with a full length spoiler you will need to drill new holes. This rear spoiler is made out of real carbon fiber and features a high clear coat finish.
Adjustable wickerbill
Item # AS-105727 Price $1,057.50 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5138
For the C7 Corvette Stingray owner that has added a carbon fiber rear diffuser. Our real carbon fiber rear head shield is a complete replacement part made 100% of carbon fiber. Simply remove your existing panel and install this right into it's place. These rear heat shields are made by APR performance and will work with OEM stock rear lower valance panel or the APR carbon fiber lower valance panel.
Item # CBX-VETTSSHIELD Price $405.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5137
This C7 Corvette Stingray real Carbon Fiber Rear Diffuser is a direct replacement of your existing diffusor. Made in the USA by APR.
Item # AB-277019 Price $1,465 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4971
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR C7 Corvette Stingray side rocker extensions kit. Made right here in the USA, this side rocker kit helps reduce under-body turbulence, lift and drag by limiting excess airflow to the under- body. Or course, if you are not into racing, this kit also provides a great visual upgrade over the factory look.
Item # FS-207008 Price $1,610.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4936
This C7 Corvette carbon fiber side front fender vent set is a direct replacement of the OEM GM plastic pieces on the right and left front fender. Simply remove your existing vents and install this real carbon fiber vents.
Item # CF-700002 Price $456.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4932
Item # CF-700005 Price $470.25 Use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4931
This C7 Corvette carbon fiber rear quarter panel vent set is a direct replacement of the OEM GM plastic pieces on the right and left rear quarter panels. Simply remove your existing vents and install this real carbon fiber vents.
Item # CF-700004 Price $565.25 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price !!!!
Website link : http://www.rpidesigns.com/shop/item.aspx?itemid=4933
These C7 Corvette Stingray Carbon Fiber Mirror Housings are very light weight and replace your existing mirror housings.
This mirror conversion kit replaces the factory mirror housings (but re uses the existing lenses and power mirror mechanisms).
Item # CF-207007 Price $665.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4970
Attachment 47851908
Attachment 47851908
We've got many of these pieces in stock and most pieces include free shipping
