Can't turn AC off
Can't turn AC off
Using AC a lot since I got my C7 a month ago. The few times I turned it off, the light goes off, the screen says it's off, but it's still blowing cold air. Anyone else experience this?
Where do you have the temperature set when you turn AC off? Some others have reported with current GM vehicles if the temperature is set to its minimum setting the compressor will run even with the AC turned off, setting it above minimum stops that behavior.
I do recall reading that, so I tried setting the temp up to 61 or 62, but still can't turn it off. If I turn the fan off, the AC turns off, but what if I want to blow air without chilling it?
If you have the temp set on LO, the AC compressor will turn on, and you'll get cold air. On any other setting, it won't come on unless Auto or AC is on. If yours doesn't behave that way, something might be wrong.
You set the temperature up to 62? That is still way low, try above the actual outside air temperature. I don't think I ever set the temperature below 75. When the unit calls for heat the AC should be off unless set to window defroster.
I was wondering about that myself as I am having the same experience. I had the temp set to low and the fan on, the AC off and still getting cold air. Strange engineering concept at GM, ya think?
The craziest part is the AC indicator light going off when you press the AC button yet the compressor really is still running .
Are you using Auto or the defroster or windshield setting because all the new cars automatically use AC to take moisture out of the interior area and especially at temperatures probably more than 10 degrees difference between outside and inside temperatures !!! That's why when I drove my car home in March when the temperature was 35 outside and I turned the temperature to 70 inside at least for about the 1st 3-6 minutes !!! Wayne
GM Manual indicates for turning off climate control you have to rotate the fan speed dial counterclockwise until off....you're not broke, it's just a quirk they should have done differently....
Another silly "why did they do that" instead of just having an "off" button
jmarkey77 (04-23-2022)
As others have said, having on LO will run AC. Also, there is a setting for Auto Defrost you can turn off in the climate control settings. In its standard ON setting this too will run the AC in many circumstances. I set mine off and now the AC never runs without pressing the AC button or on LO.
I'm gonna try setting it above 65 as some have suggested, and see if that works.
You do realize the temp you dial up is the desired cabin temp, not the temperature of the air coming from the vents?
Let's see. You have set the temp to Low, which IIRC is below 62 F. This is below ambient temperature everywhere but Canada, and the mountains at this time of year. The only way the system can possibly meet your request is to turn on the AC compressor.
As I mentioned in my post above, try turning off the Auto Defog in the vehicle settings menu. This is not the same as the AUTO button. The LO temp setting will bring AC always, but this setting will prevent it otherwise.
See page 5-43 of the manual (2014).
I leave my temp at 61, and the AC never comes on unless I push the button.
I have never set my cabin temperature below 73 and that was when I had the top down in traffic. The system doesn't blow colder air the lower you set the desired temperature. It will max cool until the desired temperature is reached then modulate incoming air to keep that selected temperature. In theory, if you select auto 72, the system should provide a cabin temperature in any climate condition (winter, summer, spring, fall) of 72.
Would some one please send this thread to Corvette engineers. I wonder what they would say!!
