Constraints - September 18 for TPW of October 20
Moderator
RPO............Description.............. ..................Availability
FAY............Carbon Fiber Dash..............................30%
Z51............Performance Package............................55%
C2Q............Dual Roof Package (Body Color and Transparent)..0%
C2Z............Visible Carbon Fiber Roof......................20%
C2M............Dual Roof Package (Visible CF and Transparent).20%
EFY............Body Color Vents............... ...............Option no longer available
CFZ............Carbon Fiber Ground Effects Package............option no longer available
SDN............Black/Silver Stem Valve Package................Option no longer available
CFA............Standard roof (painted)........................35%
1Y*67 & E57....Convertible Tonneau Cover/Carbon Fiber Inserts..0%
1Y*67 & S3Z....Convertible and Decklid Liner..................Option no longer available
5ZU & G1B......Z51 Style Spoiler and Shark Gray...............Not Constrained
5ZU & G1H......Z51 Style Spoiler and Daytona Sunrise Orange...Option no longer available
SB3 & G1B......Wing Style Spoiler and Shark Gray..............Option no longer available
SB3 & G1H......Wing Style Spoiler and Daytona Sunrise Orange..Option no longer available
Z07............Z06 Performance package........................60%
CFV & Z07......Carbon Fiber Ground Effects and Z07 Perf Pkg ..25%
CFZ - Z07......Carbon Fiber Ground Effects minus Z07 Perf Pkg.20%
Target Production Week of October 20, 2014 for non-Z06. TPW of November 3 for Z06's.
Note Z06 Constraints are now on the list.
Target Production Week of October 20, 2014.
Moderator
It's difficult to believe so much thought and engineering was put into this car only to find that GM can't get the parts to make it. Back 15 years ago, if you were a supplier and couldn't get parts to the plant, there were big fines to pay. Especially if you stopped the line. Obviously, the companies causing these problems are the suppliers who quoted the cheapest. This far into the production run, there shouldn't be an issue getting a base roof panel.
The GM people on this program who are responsible for seeing that these suppliers are competent and that the tooling is designed, built, and purchased to do the job as required should be held accountable.
Now maybe someone has figured out a way to produce CF body parts using a stamping machine. What, are you kidding?
So, should Chevy have opted for a removable CF roof? Hindsight says no. I maintain there is a difference between using a CF hood with two fixed points and a targa roof with no fixed points and combining the productivity limits inherent to using CF with the structural problems that are part and parcel with a removable roof, voila: we have a problem, mission control.
My apology Zymurgy for hijacking but I obviously reached a point where the abject lack of understanding regarding using CF caused a temper tantrum, but I believe my point should be published.
Laborsmith
Moderator
Well, actually...
2014 Corvette Stingray
The 2014 Corvette Stingray base model hood, premium exposed weave roof, and painted roof will be the first vehicle platform produced in the patented pressure press technology which yields a part in sub 20 minutes.
Thanks Zymurgy for that info; I had missed it.
Laborsmith
I also don't see where the CF roof skin has any more structural purpose than the hood since the roof has a frame that the panel is glued to like my transparent roof does. I see it doing little more than holding the headliner up.
My point is that there are volumes that suppliers have to quote to and cycle times have to be met to meet those volumes. If the tools and operator can't make the part in the time necessary, then someone better buy a 2nd tool and hire another operator to meet production volume. It's not uncommon to double tool in order to meet volume. Ford has 4 redundant single purpose tools all making the same aluminum cab structure part (one part per truck) for their upcoming aluminum F series. Cycle time on each tool is around 15-20 seconds counting load and unload time.
I had not noticed that but now I see the problem: the pressure press technology may well be patented but that does not mean it will effect viable product in a sub 20 minute time frame, How do we know? Does the continuing constraint on the standard body color painted targa roof not tell us?
Laborsmith
Laborsmith
12,000 units a year: wonder if that is about how many non-transparent coupe targa tops came off the line for the 2014 model year? I did notice the vendor is adding staff to increase production.
Laborsmith
Laborsmith
Don't see the correlation between a part being on constraint and the inability to produce the part in 20 minutes. Simply, that's 3 an hour or 48 over a 16 hour day. That's 12,000 units a year over 250 working days. The real question is at what capacity is the facility setup to handle. We know that Plasan produces parts for more than just GM.
You will make how we tell you, when we tell you, and for us only.
If we don't sell it you don't need it.
Just saying
This is the only mention of capacity that I see on their site:
http://plasancarbon.com/facilities
What is with the "option no longer available" for many of the parts ? Where they ever available ? If not why do they bother announcing them as options for the car if they are never going to be available ?
If you order a z51 or a zf1 in Daytona orange what color will the spoiler be. I'm confused by the constraints that say z51 spoiler and Daytona orange. No longer available. Doesn't the spoiler come with both packages. And if so what color will it be
Working as a chemist for a worldwide chemical company I can only say that constraints are unfortunately the way my company operates. Supply and demand keeps little or no inventory on hand which is common in today’s manufacturing. This is why Corvette orders are taking so long. Companies do not want to keep inventory of any kind. Delaying supply also keeps prices up.
Yeah, that's a shame too. I remember back when Fisher Guide was making components as a division of GM, and several of the "Engineers" that followed up on tooling development and capability were dumber than bricks. You could tell that they couldn't understand what they were looking at when you showed them drawings. I think most were foreigners that had "degrees" and would work cheap. I did meet some smart ones, but there were plenty of droolers to go around.
Moderator
5ZU LPO, Z51-style spoiler Genuine Corvette Accessory
Not available with (5ZV) Carbon Flash painted Z51-style spoiler, LPO, (ZF1) ZF1 Appearance Package or (R8C) Corvette Museum Delivery.
If you order a Daytona Sunrise Orange Z51, you'll get the Orange spoiler. Ordering ZF1 on a non-Z51 (only way you can order ZF1) DSOM will also gut you a DSOM spoiler.
You just can't order RPO 5ZU on DSOM unless it is part of another package.
