"Base" C7 sway bar
Glen / Higgs which installation method is preferred and did you each use, lifting using the body frame points or by using a drive on ramp? Suspension compressed vs hanging. If it even makes a difference. Thanks.
I'm trying to only do meaningful performance mods to by base C7 not cosmetic like with my '05 C6 Z51.
I find it interesting that many of those who feel that the Z51 should only be bought by those who "track" their C7 are the same ones getting ZF1 packages, sway bars, Z51 shocks, etc. and in essence are ending up spending more than they would have without getting the complete package they would have had they ordered the Z51 to begin with. Also, no ability to get the MRC, larger vented brake rotors , functional rear airflow vents, ELSD, dry sump.
Those that purchased this option at its original $2800 price got the bargain of the century (tracking it or not).
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Like Glen I'm only adding what I want 'a la carte. The Z51 sway bars will go a long way getting me where I want to be for only $300. Next? maybe larger wheels when I need new tires that will be lower profile. The TSW Nurbugring Wheels in gunmetal gray with mirror face look great for under $1500. The base braking with no dust is perfect for me and I don't do enough sustained lateral G driving to need a dry sump.
The price is so good I was about to order the sway bars but I had two straight weekends of spirited driving on Kentucky back roads, now I'm not so sure. C7 is a very capable car the way it is!
night and day!
i autocross with nepascca and some nccc events, ( at least 15 events this year with my c7) i started the season bone stock( a6 hoosiers on c5 z06 wheels),at first event someone took pictures and posted them to me showing me that my car looked like the love boat out there, it was sad! then i added bars, that $300 was well spent, then $300 more on z51 shocks, new pictures no longer get me sick, F.Y.I. IF YOU DONT RUN STICKY TIRES, i would not change a thing. the skinny dodge neon size tires that come on car will give out( slip) long before body rocks and rolls, i run 315/35/17 up front, 315/30/18's out back. hope this helps, it might not be skidpad numbers but feel and THE LOOK OF CAR running hot/fast means a ton to me.
im just saying
i disagree and have written so, as a DD, I can feel the diff on railroad tracks, speed bumps and making emergency darting at interstate speed. The car recovers quicker. For me, who does not care about the track at all, I def can tell the diff.YMMV....no right or wrong answer here, we are all different...
But I don't think "a must" was ever intimated here. and if this was $500-700 I would not have spent the money. For $300 or so, it's doable for me.
And although this is highly irrational, a perf shop that has done a few near me, tells me a few want it because it just looks like there is something missing...LOL
#34
Sure it would be easier using a lift, but with the ramps, other than having to crawl around on the floor, no problem.
I doubt it would be any different using ramps with a C7
