"Base" C7 sway bar
"Base" C7 sway bar
You owners of a "BASE" C7, do you have a rear sway bar on the car from the factory? I've been told all the mounting holes are there but no bar is on the car and I'm trying to find out if that is normal or not....any suggestions??
Received 2,379 Likes
No rear sway.....Z51 bar (and aftermarkets) is a direct bolt in, 10 minute job.
My 1Lt did not come with one. I just installed a rear Z51 bar yesterday on the floor of my garage in an hour. I have the front and will get around to swapping it out sometime...
The Z51 shocks are a great addition too.
I installed them on my LT1 right after I got the car. Gene on this forum has the complete kit down to every nut, bolt, and bushing at a great price. Got for it. Makes the car totally flat in maneuvering.
yes, there is a difference....not a different car but the car rotates a bit better. you don't need the front sway bar, the Z51 is a little bigger but you probably won't notice....there is a bigger difference in the springs for sure.
the Z51 shocks help make it feel less wallowy.
I've got Z51 shocks, sways, wheels and tires, spoiler, etc....almost a wet sump Z51, lol......
eventually I'll sell the shocks in favor on coilovers.
Here's the complete Z51 Sway Bar kit Gene at GMPartsHouse assembled and sell for about $290.
This is what I had installed on my ZF1 by my dealer before delivery.
Tom
Tom
The z51 was designed for the sway bar kit on it. The base car was given a diff weaker front sway. Just my opin, but i would never put on the rear z51 setup and let the front stay a weaker sway. That's what Lashway recommended and also why Gene sells it as a kit.
if you look at aftermarket sway bar history, many sets will raise the rear stiffness considerably over the front (deltas). the base model lacking a rear bar is purely a travesty, this is not a pickup truck.....
when I installed the rear bar I noticed a difference, when I installed the front bar a couple weeks later, not really. almost as if the car was designed as a Z51, then they backed everything off a notch, then removed the rear bar entirely......it's the biggest aspect of the suspension differences (except for potential MR).
i agree they were designed together but the fact of the matter is the difference is VERY minor.
I will be curious to learn about the Z06 sway bar's, I installed them on my 99 FE1 coupe and 06 Z51 and liked the new feel even more than with the Z51 bars. Same with the shocks.
Tom
Tom
dont get me wrong, i replaced both as well, i am just saying that it isn't the end of the world and your car isn't going to slide off the road if you don't replace the front.
Premium Supporting Vendor
Thank you for the referrals. We now sell the front and rear Z51 sway bar add-on kit with new front sway bar insulator bracket bolts for $296.66 + shipping. We sell so many that we put a stress on the GM system so it takes us approximately 7-10 business days to get the kits before we can ship them out. To order, click on the link below.
http://store.gmpartshouse.com/parts/...&siteid=214638
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Glen / Higgs which installation method is preferred and did you each use, lifting using the body frame points or by using a drive on ramp? Suspension compressed vs hanging. If it even makes a difference. Thanks.
I'm trying to only do meaningful performance mods to by base C7 not cosmetic like with my '05 C6 Z51.
