Penzoil Platinum
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
If it's not DEXOS rated, it's dead in the water for the C7 regardless....
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Looks like you're good to go if you want to use it!
"•GM dexos1™ Certification (SAE 0W-20, SAE 5W-20, SAE 5W-30)"
fr. here: http://www.pennzoil.com/motor-oil/pe...Specifications
If the Pennzoil website is up to date, it says that Pennzoil Platinum does meet dexos 1 spec.
OEM specifications:
•Chrysler MS-6395 (SAE 0W-20, SAE 5W-20, SAE 5W-30, SAE 10W-30)
•Ford WSS-M2C930-A and WSS-M2C945-A (SAE 5W-20)
•Ford WSS-M2C929-A and WSS-M2C946-A (SAE 5W-30)
•GM 6094M (SAE 5W-20, SAE 5W-30, SAE 10W-30)
•GM 4718M (Corvette and Cadillac) (SAE 5W-30, SAE 10W-30)
•Honda/Acura HTO-06 (SAE 5W-30)
OEM specifications:
What's really the reason for Dexos 1 ratings? Does anyone know? Funny how everyone is all up in arms about synthetic oil when conventional oil has been proven to work just fine for engines that are designed and produced properly. My friend had a 1987 CRX that used conventional oil and ran for 340,000 miles until he sold it still in running condition. The engine was never rebuilt or had any repair. All he did was change the oil every 3K to 5K miles with whatever the oil change places put in it. If you change your oil every 5K I don't think it really matters but I could be wrong...
I have been using this oil since my 2007 corvette was new. Had to have the cam and lifters changed at 85,000 miles and the inside of the engine looked brand new. I change the oil every 10,000 miles. The lifter problem did not have anything to do with the oil. It was not sticking, it had collasiped. Also run it in my avalanche with the same change interval and it has 160,000 miles on it and it has never been in the shop.
I feel that Pennsoil is one of the top brands of oil produced and I have been involved in lubricants for around 30 years, specifying lubricants for one of the larger offshore drilling companies.
Apples and oranges difference in engines and technology!!! Without going into every detail about a '87 Honda engine vs. a '14 LT1 and your comment about properly designed and produced engines, let's just say.... ah forget it. I really don't mean any disrespect but if you have to ask that question, you probably just won't get it. Sorry.
You can argue that GM is using its Dexos 1 certification as a cash grab because it requires a licensing fee to oil companies to use it on their packaging. But you can not compare a conventional oil to a synthetic or syn blend oil.
AND do you really think conventional oil is for engines that are designed and produced properly regardless of the vehicle manufacturers engine oil specs???? (I guess you're saying that most engines are not designed and produced properly and so they need a synthetic or a syn blend to keep the engine from failure? Huh?????)
When you get your C7 get your buddy to give you a couple of quarts of the oil he's been using since '87 in his Honda. Love to see the reaction when GM gets the warranty request.
Your buddy’s 340K miles is a sample of one, meaningless statistically. Because the vast majority of cars, particularly older cars are running on “mineral” oil, you are certain to find cases where the car has run an amazing number of miles. Still says nothing to refute the superior performance of synthetics.
You’re on a Corvette forum. Older Corvettes specified or at least strongly recommended Mobil 1. There was no Dexos then, so GM had no financial stake in Mobil 1. Think they recommended Mobil 1 just to make you pay more for an oil change? I don’t think so. Don
I like Pennzoil oil as much if not more than Mobile one, I have been using it since I tried it in the 90's in all kinds of engines mostly high milers.
When I bought my truck in 2012 I didn't use it because at the time it wasn't dexos certified but now that it is certified I will use it in the truck and in my corvette.
I had a few problems with Castrol and on 2 different occasions, now I won't use it at all.
I've never used this oil, and Its probably difficult to compare the performance of various synthetic oils against each other in everyday driving. I had a repair done to my daily driver Honda which required the oil to be replaced. I didn't want to pay the high cost of the dealers synthetic, which is Penzoil Platinum, so I had them use their regular stock. I'd been running Mobil One for years and when I changed the oil it was much blacker than I'm used to seeing it running less miles on the change. I use synthetic oil in every engine I have from a two-cycle trimmer to my lawn mower.
Let me say in advance, none of my comments are intended to stir the pot. Oil seems always end up in debate here and other enthusiast forums. There is a very active 'oil community' with lots of knowledge over at www.bobistheoilguy.com (BITOG)
I'd recommend doing some reading in the BITOG passenger car section before drawing conclusions regarding modern oil formulations based on 'common knowledge' from even 5 years ago. Sure, not everything has changed, but there has been a lot of evolution in motor oil relatively recently.
Here's one example. For us C7 owners and other DI engines, the lack of fuel wash over the intake valves can lead to significant deposit problems if the PCV system isn't up to the task. For this DI reason, the NOACK volatility, for example, is one of the most important ways to help reduce the rate of deposit. And this is only one of the areas improved by recent advances in formulation.
And there are many other attributes for motor oil performance that need to be balanced like fuel economy (both in regards to viscosity as well as reduction in additives that reduce catalyst life), wear, etc. And cost...
The reality is probably that any properly certified modern motor from a reputable manufacturer in the semi to full synthetic class will cover 99% of normal use on recommended drain intervals. For racing or other extremes (super hot, super cold, high loads, etc.) there will be oils whose formulation and additive packages will be tailored to those cases. These are typically the full synthetics, and this is where opinions are even more polarized regarding base stocks and other variables.
I personally use Pennzoil Platinum and Ultra over Mobil1 (based on my research on BITOG). I use good filters from Wix or Mobil1. I typically go 5k miles on an oil change. And this is probably way too frequently since I do have used oil analysis (UOA) done on all my cars trough Blackstone. All reports are very good, and they always advise that I can go at LEAST 7k miles based on my results (both TBN and wear metals). But these are my results, and certainly others' may vary.
So in the end, my only advice is to read up on some current information from reputable sources before rushing to judgment on all this new fangle oil mumbo jumbo...
The dexos1 and the ILSAC GF-5 are recent evolutions, and the spider chart below indicates the similarities and differences.
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
I'm interested in hearing his Castrol problems as well. I've been using Castrol in every gas 4stroke engine I've owned (small/auto/marine) since 1963 without any issues along the way. Started using it back then in my Triumph Cub Enduro dirt modded bike. Only my C6 and C7 have been otherwise with Mobil1.
The first time I used 5 30 full synthetic in a VW it vanished out of the engine it was so thin no leaks no smoke, just 3 quarts missing after 100 miles of driving in town.
The 2nd time I used regular castrol to break in a newly rebuilt engine, at 50 miles the oil pressure dropped to nothing after changing the oil the pressure popped right back where it was.
Never again, I love john force and all but not what he is selling
