Would you still buy a new Corvette with a door ding?
I went and looked at my corvette that i should pick up this week. It has a door ding on it. I am pretty paticular about my cars and feel that i will never get the paint job like the factory. It also appears to have quite a bit of orange peel.
What would you do?
What would you do?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Depends on the color. Some are much easier to blend than others..
Doesnt matter what any of us would do. Sounds like you already know what you want to do. If its going to pi$$ you off every time you look at the car, then you should consider not taking delivery. You could have the repair made and then make your decision. And orange peel can be made better with wet sanding if you want to go thru the cost and time.
I have no idea where everyone gets this idea that "factory paint jobs" are better than your local GOOD body shop. It is always better locally, if the guy is a pro.....a new car can be matched PERFECTLY by someone with computerized spraying and skill.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
And if you have an entire door painted there is no blending, which is how repairing a paint flaw on a door should be done (and is far easier for the painter anyway.)
With all these so, so paint jobs coming out of Bowling Green, I would think that a "local" guy would stand a better than even chance of exceeding factory paint. And, a ding and orange peel on a new Vette would be a no, no for me after spending 65K.
Who knows, the next one that comes along you would buy might have had a ding in it that was touched up and you are the unsuspecting buyer.
in any event $hit happens, once you own and drive the car. it will get chips, dings, things brushing up against it while parked safely in your garage.
you could use the ding as an excuse to justify a better price on the car.
There are bigger things to focus your attention on.
Have to agree, I do not see spending that kind of money and having to accept a repair of a door ding and what I assume is excessive orange peel in the finish.
My take on this is that there is no perfect car, and expecting that is setting yourself up for disappointment. (However, that's not to say that you don't get to set your own expectations.)
Good luck, whatever you decide.
Don't know this for a fact, but I am sure paint damage occurs at BG and they spot repair the damage. I do know that cars get damaged in transit occassionally and get repaired by the dealer. Every dealer has a touch up guy that paints scratches etc. Usually the buyer never knows.
The factory advantage of the "better tougher paint job (as far as GM is concerned) is LONG GONE!
Moderator
A "door ding" is not very descriptive. Did it go through the clear coat? If not, it can probably by taken care of by polishing. Photos would be immensely helpful here - for both the door ding and the orange peel.
B) Good luck finding a body person who is a "pro". Most just get by, if that.
Michael
St. Jude Donor '10-'11-'12-'13-'14
Exactly right. I've tried to make that point in the past here. Cars are damaged in shipping, while sitting on the lot (just watch the amount of dealership and customer traffic sometime), and even while in for service. They are repaired and the owner never knows.
Nonmetallic colors can be matched very closely without much difficulty. Metallics (especially tintcoats) are near impossible to match. Even if you get the shade right the alignment of the metal flakes is not going to be oriented in the same direction as the surrounding panel so in some lighting the paint will look like it matches and in other lighting it will look like a totally different shade. This is why most reputable shops do blending on metallic paints.
