Seat Memory question
On my wife's new 2015 M7 coupe, we've programmed her seat position into memory button 1. Is there a way for it to move to that position if the start button is pressed without the clutch depressed?
With the seat in the entry/exit position she can't reach the clutch. Obviously she can press and hold the seat memory button down, but it would be more convenient to just press the start button once to move the seat and then depress the clutch, and then press the start button again to start the car.
Thanks,
David
Thanks,
David
I just hold the switch, both for exit and seat position 1 or 2. Not really much gain when you think about the other button pushing/clutching for seat movement.
Received 1,295 Likes
M7 seat memory update
Thanks,
David
Thanks,
David
See this thread:
https://www.corvetteforum.com/forums...te-for-m7.html
Ron
There was a software update you could request for 2014 M7 that would do this. I don't know if the seat recall on start option is standard on 2015 or if you need to have the dealer install it. You can press the start button without clutch and the seat moves. Press with clutch and seat moves / car starts.
See this thread:
Ron
See this thread:
Ron
Right now when she shuts off the car the seats and steering wheel go to our programmed exit positions. If she gets in and presses the start button the seat moves even farther back. She has to press the 1 button on the door or slide down and press the clutch for the seat to go to the memorized position.
The settings are: Vehicle>Comfort & Convenience>Auto Memory Recall>On - At Ignition On.
David
Moderator
Maybe the 2015's still need the update! I followed the instructions in the manual and read that thread and watched the video. Do I have to pair the remote with the setting? Her remote was in the car when we memorized the settings.
David
David
You have the correct setting, and you would not have the "At Ignition On" option without the update.
David
David
Thanks,
David
Thanks,
David
David
David
Moderator
Make sure the eBrake is set, or it won't work with the "Ignition On".
Try the other fob
Try the other fob. The car assigns fob #1 to the first one it "sees." Make memory settings #1 and #2 different and then try each fob. You'll figure out which one the car thinks is #1 and #2 pretty quick.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Didja set Settings/Vehicle/Comfort And Convenience/Auto Memory Recall/On-At Ignition On, and Easy Exit Options On?
Moderator
Make sure your exit position is not set so that the seat back is hitting the bulkhead limit switch (don't set it all the way back).
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
Guess they could not make it a true software “upgrade” and operate like the C6 with a one touch press. Either the software person did not understand what the C6 did or it was the same person who built in a “move to the preset position when the door opens!” Have never understood who would want that feature! Maybe they farmed out that software to a person overseas who never drove a car!
Agree, except I have the Easy Exit set to ON and Auto Recall to OFF. It does move by itself to the exit position when I open the door and stays there until I push and hold the memory button. However been at this for a year so have gotten in the habit of pushing and holding the seat memory button with a finger on my left hand while I pull the belt buckle over with my right. My wife is always saying I should learn to "multitask," so this is my multitask! Pushing the start button with my right hand (I can’t reach the clutch with the seat all the way back) would mean I could not multitask and do both at once! Still have to push in the clutch and hit the start button either way!
There is no need at all to press any of the memory buttons....
The firmware update WILL fix it so you only need press AND RELEASE the START button and whichever memory matches the FOB you have in the car will be recalled. Once the seat moves into position, you can then depress the clutch pedal and press START again to start the car.
For those wanting to know how to set the features for mn7 call me. I set down push start button on fasten my seat belt close door and seat is in driving position. I set emergency brake shut engine down open door seat moves to the exit position I never touch a button if you are having to hold buttons you have seat to far back or have something else checked on that should be off. Oh and the 2014 updates are whats needed if you haven't done that yet.
770-886-8843 cell 770-316-8528
z51vett
Doug
z51vett
Doug
z51vett
Doug
Perhaps you misunderstood. I have no problem, been doing the same thing since mid-October 2013! I do two things at once, push and hold the memory button with my left hand while I buckle the seat belt with my right! It’s easier to grab the belt with the seat back so I do both at the same time!
I was hoping the new (not better in my opinion) software would be like the C6 but it is not so I won’t bother.
Just like closing the rear hatch, I keep the door open and it’s fine. I’m happy and now can stand by the driver’s door, gently push on the hatch left edge with my right hand and it latches fine! To each his own. Fewer work arounds with the Vette than my Microsoft products, Dreamweaver web software etc. etc.!
