Exit Memory button not working
Read the manual, tried setting the exit button with car running, ignition on and off, emergency brake engaged/disengaged, with/without seat fully reclined or fully moved to the rear, recall at ignition "on", primary fob in pocket, and NOTHING. The car refuses to retain an exit memory?!?
The memory one and two work fine, do I need a re-flash or is this a simple case of operator error?
2014 Black/black Z51, 3LT, Auto trans, no engine mods (just ceramic tint and Mothers wash/wax)...
Thanks in advance,
Mike
Thanks in advance,
Mike
Thanks, I tried that but perhaps I need to move the seat a full 2 inches forward. The inch I moved it didn't work. Moving the seat forward that much kind of defeats the purpose though. Hopefully it's a computer glitch, I'll try your suggestion though, thanks again!
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
It should work with it ~1/4 inch forward from max back, that is here mine is set and works fine. Be sure you're hitting set then within the 2 or 3 seconds allowed the exit position button, just like the set memory buttons. If you are, perhaps an issue with the button.
Moderator
Do you have Easy Exit turned on?
Settings > Vehicle > Comfort and Convenience > Easy Exit Options > On
Good point. Also, if you don't have the new software installed by the dealer then also be sure Auto Recall is off or with a standard shift the seat will return to the memory position of the key fob when the door opens!
Thanks, that was a pain as well, seat was always going to memory one upon door opening. Changed it to "at ignition on" after reading in this forum. Still not able to lock in exit memory, I'll try auto recall to off to see if that works but I'm afraid that will cancel the auto memory...
Really? I have only been successful programming my memory buttons by simultaneously pressing the SET and other button. And when I do this the programming beep is immediate -- which irritates me due to lack of ergonomic finesse, for lack of a better term. Even before taking delivery, neither the sales guy or myself could get the buttons to memorize the seat position. I tried every combination of press-release, press-hold, and nothing works except a simultaneous pressing of SET and the desired memory button. Do I need a firmware update?
