C7 Battery Life
Would appreciate the info. I have 3 digital meters. All read about the same but the one I use is a good one with a shunt allowing a 20 amp measurement. That is the one I brought to the battery store and checked one of the batteries on their shelf along with their meter and both read 12.90..
I didn't have time to pull of the carpeting mat to get to the battery as it's too stiff to pull off easily, but just took a quick measurement at the power outlet, and read 12.45V, likely due to voltage drops in the wiring harness with the interior lights on. I'll have to hook up to the battery directly and let the lights shut off to get a better measurement.
A quick measurement of the voltage at the power outlets on the center console showed 15 volts with the car running, which is higher than expected, but again, I'll need to read it at the battery terminals to get a good reading.
As far as the Corvette Battery Protection package, it's a 3300 Corvette logo Model 1051 maintenance charger with a 3.3A max output, which drops to a pulsed maintenance charge output when the charge voltage reaches a threshold of 14.4V, with the current output dropping below 0.4A. At that point it puts out a periodic charging pulse to hold the voltage.
If for some reason the voltage drops below 12.9V again, it goes into charge mode again.
It's similar in operation to the Schumacher 1.5A maintainer I have, except it has double the charge current capability and 4x cost.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
When you were measuring the battery, were you doing it in the car with the hatch open and the courtesy lights on? That may be why the reading was lower than expected.
I have checked at the battery when going to fuse 37 for my radar detector. When the hatch lights go out (~10 minutes) the same 12.4 volts as the alternator terminal. The key to pulling up the carpet is to unclip the plastic wheel well cover from the bottom clips before tugging!
I used the equivalent to the Chevy 3300 maintenance charger I bought on the net for ~$50 a year ago. After a day and all charging finished and in the maintenance mode, removed it and when the surface charge was depleted (24 hours) still read the same ~12.4 volts!
I use a Schumacher charger on my Street Rod. I had a problem with one I used for several years it failed while still on warrantee with the green light still on indicating it was charging, which is was not. I went to Autozone and bought a new one but wanted it replaced as a back-up. They were no help in replacing, gave me a bogus address to send it to that USPS Click N Ship (that I use all the time) would not send to. Emails back and forth were no help. Dropped the issiue with them. If it fails (I do check the Street Rod voltage from time to time to be sure it’s working) I’ll use the one I bought for the Vette!
As I have mentioned I am not concerned the Vette started fine after a 2 ½ week trip this summer. Just curious what others read.
I made a measurement at the battery terminals and it was 12.7V; I did it from the back with the hatch switch closed manually to shut off the lights. When the lights were on, I read the 12.4 from the APO outlet.
The current draw in standby was generally about 10mA, with some brief spikes of about 30mA (just using DMM so I couldn't tell the duration).
Those of us that don't drive our Corvettes(or motorcycles, riding lawnmowers, boats, classic cars of all makes, etc) on a regular basis find that a float charger is a wise investment.
Do yourself a favor and buy a battery tender or float charger or someday you will walk out to your Corvette and find a dead battery.
Thats a given! Besides its healthy for the battery to always be fully charged with small constant drains on it-
Let it sit for a bit, and then take the measurement at the battery.
Be sure not to forget you have the latch in the closed position, and hit the release button before trying to close the hatch!
I also made a measurement of the charging voltage with the engine idling and it read 14.76V after cold startup.
The standby current draw generally showed about 8mA, with momentary spikes of maybe 30mA, maybe partly due to the dash security LED flashing.
The following 2 users liked this post by aklim:
CorvetteMike2024 (05-22-2022),
miami08VETTE (05-23-2022)
Received 19,287 Likes
'20-'21-'22-'23-'24
