Infotainment screen problem
Infotainment screen problem. It's back!
Took a hard left turn and my infotainment screen started acting like an old-fashioned TV with a vertical hold problem. After I parked it for an hour, seems OK. Loose wire?
Update:
I spoke to the service manager at my dealer. He said he had heard of the problem with other Stingrays, but said he may be a one-time glitch and might not happen again. Well, from reading this forum, I was sure it would come back, It's not a one-time glitch. Yesterday, on my way home, it started rolling again, like an old TV with a bad vertical hold. I had to put the screen down because it's very distracting.
My question is: How long does it take the dealer to fix this problem? My drive to the dealer is one hour each way and so, I have to take a day off work.
Update:
Could be a connection, or maybe something was jarred in the corner. I have seen other posts of similar problems that occurred once, then went away on the next restart. At any rate, you have a warranty. Not to worry.
I had the same thing happen. Went in for a reflash. 2 months later it came back worse than ever. They then replaced the screen with a whole new unit. Took 1 day. It's been perfect ever since. Good luck.
I've had the same symptoms a few times. Problem starts out really bad, makes the screen almost unreadable. But in the next 15-20 minutes it gets better and better until it is back to normal. I'll mention it to the dealer next oil change, but if it's not doing it then will they do anything? Or will they chalk it up to "cannot reproduce"?
Hi SRQStingray,
If you decide to head into the dealer for this, please let us know. We'd be happy to contact them, and look into your vehicle further!
Marissa
Chevrolet Customer Care
Marissa
You are probably going to need a new screen . They will try to update the software first . It took me 5 times going to the dealer before they gave me a new screen . Good luck .....
Thanks, Marissa. I will watch it for a few days and if necessary, take it to Stingray Chevrolet. It was strange in that a sharp left turn cause the problem. Seems like a bad connector or loose wire.
After a week of this, I waited til it started on my way home and went to dealer. Pulled in without shutting down so tech could see it.
I ended up with a new screen. Works perfect again.
Hey Professor! I had same problem. Intermittent display issues and vertical scroll that would go dark at times. It was doing this on any page even during backup cam mode.
Thanks,
Jeff M
Update:
Update:
Update:
Update:
I'm experiencing same problem. See the video I've added in this other thread: https://www.corvetteforum.com/forums...een-issue.html
In my case, they've attempted to do the reflash. It worked for 1 day and then issue started happening once again. They are replacing the whole navigation screen as we speak (I am at the dealer now), car should be ready by noon according to the dealer. Fingers crossed nothing else goes wrong...
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
^^^^ Matt, they did the exact same thing with me. The reflash didn't help. The problem with mine is that they ordered the screen but there's a back order on them because this problem has become so prevalent. I'm not sure when my new screen will arrive.
After the failed reflash attempt, I brought the car back to the dealer last Tuesday, May 26th. It took 8 days for the screen to arrive here at the dealer. They are installing it today.
Mine is also doing the same thing, new screen is on order.
When it started, i shot some video with my phone to show them, because, of course it stopped doing it by the time I got the car to the dealer
